Old 10-24-2014, 11:07 AM
3goats's Avatar
3goats 3goats is offline
Default SPI Epoxy
Can SPI epoxy primer be used on bare metal ? I've only used it on the endura bumper repairs and was wondering if I should use something different on bare metal or does SPI work well in either case. I'm having a 69 Judge dustless blasted today and want to cover up the bare metal asap.
Old 10-24-2014, 11:48 AM
webfoot's Avatar
webfoot webfoot is offline
"We are known on enthusiast message forums worldwide for our Epoxy Primer. All four
colors have outstanding adhesion to metals and aluminum, excellent chemical resistance,
outstanding corrosion protection and can be easily sanded by wet sanding, dry sanding or
DA sanding. You can also apply body filler and 2K primer over our Epoxy Primer for up
to 7 days without sanding."
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 10-24-2014, 11:11 PM
3goats's Avatar
Awesome Thank for that info. I got car totally blasted outside. Took parts off and did inside doors, trunklid, hood, valance. Total blast time 2 hrs. Not much bondo in this judge but bondo takes a bit longer. No warpage at all works great.me and a buddy are doin this here in Alberta. Big or small parts.Total time 5 hours.
Thanks Webfoot
Old 10-25-2014, 04:14 PM
6t7goat 6t7goat is offline
Used spi epoxy on bare metal on this one and it is holding up great.
http://forums.maxperformanceinc.com/...d.php?t=666467
Old 10-25-2014, 05:11 PM
webfoot's Avatar
I've used it, stuff is good and not as expensive as many others - if there is no dealer in your area they ship it for free.
-Jeremy
Old 10-26-2014, 01:29 PM
3goats's Avatar
Thats good to know.
No dealer that I know of here in AB.
I had to order out of Ontario the last time.Thanks
Old 10-26-2014, 05:56 PM
jamesn jamesn is offline
I started using it this past spring for the first time. I'm not an expert, but I took my time and everything seemed to go well. It sprayed out very nicely.
Like anything else, surface prep is everything. SPI's web site is very informative. Check the product info and the forums.
Jim
Old 10-26-2014, 06:50 PM
webfoot's Avatar
Originally Posted by 3goats View Post
Thats good to know.
Had not noticed you were in AB. Not sure if it applies in that case, but its worth a call anyway. Very helpful and the owner himself will take calls and reply to tech emails.
-Jeremy
