1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 11-10-2014, 11:05 PM
SteveGB21's Avatar
SteveGB21 SteveGB21 is offline
Send a message via Yahoo to SteveGB21
Cool Tech tip on the rear lower control arms.
I found out today that if you buy the inserts for the '64-'72 GM A-Body Lower Rear Control Arms, that they also will fit the '82-'02 F-Body. That is what I will do instead of buying a set of control arms. If anything helps with saving money (only got the polyurethane bushings) then that will work for me.
Now, if I only can obtain an insert for the panhard bar.
Old 11-15-2014, 11:24 PM
TTOP350 TTOP350 is offline
I just take some flat steel and weld it in from bushing to bushing. Did that back in the very early 90s. Some of the early 82-85/6 cars had that bolt in reinforcement from the factory. But that is a great tip, will add to my melon..
http://www.fquick.com/garages/viewga...ewimg&id=74990
"You people have stood in my way long enough. I'm going to clown college."
-Homer Simpson
Old 11-18-2014, 01:03 PM
SteveGB21's Avatar
Default I will try that.
On the steel, I will do that. Thanks.
