Old 01-03-2015, 03:33 PM
goodwrench goodwrench is offline
Default Power top cylinders
Can anyone give me a general description of the procedure to remove the power top cylinders on my 65 Lemans? Do I need to remove the back seat? Do I need to remove the top assembly? Also, does anyone have a lead on rebuild kits for the cylinders?
Old 01-03-2015, 05:27 PM
Jeff Hamlin's Avatar
Rear seat & side panels need to be removed to access pump lift cylinders.
Top can be un-bolted and remain on car.
Might want to pick up a '65 BODY MANUAL it covers most Folding Top info;
Old 01-04-2015, 10:24 AM
olde-goat olde-goat is offline
x2 on the previous removable process. Save yourself a lot of grief and install new cylinders. All of these were filled with brake fluid from factory which typically leads to pitted pistons. Install new, flush out lines and pump. Pump is easy rebuild with new o rings. Replace with trans fluid. Your top and paint job will love you for the effort.
Old 01-04-2015, 11:07 AM
3 Deuce 64's Avatar
3 Deuce 64 3 Deuce 64 is offline
Send a message via AIM to 3 Deuce 64
I've used clear power steering fluid in my cars for years .
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves." Abraham Lincoln
"A free people ought not only to be armed and disciplined, but
they should have sufficient arms and ammunition to maintain a
status of independence from any who might attempt to abuse them,
which would include their own government." — George Washington
Old 01-04-2015, 01:08 PM
PW steering also good, I just found it easier to see air bubbles with pink fluid when I was purging the lines.
