Old 01-10-2015, 03:01 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
Default Laptop Charging ?
With the charger plugged in it says (plugged in not charging). It will charge once in a while. The battery holds the charge and doesn't die fast. Would this be a bad charger?
Thanks,
Eric
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
Old 01-11-2015, 01:31 PM
Deadhead's Avatar
Deadhead Deadhead is offline
I had a brand new cable that came with my phone that did similar. I would try another or get a new cable before I did anything else. First rule of troubleshooting - try the easiest and least expensive things first.
My son had a PC laptop that did this also, and we later found that the fine cable about an inch form where it plus into the machine had broken inside the insulation. Too much bending at that location.
It can do damage to the device if not repaired.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 01-12-2015, 01:23 PM
PMD1969's Avatar
PMD1969 PMD1969 is offline
If its a new laptop the machine is "conditioning" the battery for long life. Mine will charge the battery to 75% and will only top it off once a month or so.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 01-12-2015, 08:44 PM
Thanks, it's about 5 or 6 years old. I will look into getting a new charging cord.
Eric
Old 01-13-2015, 12:23 AM
PMD1969's Avatar
More than likely its your battery if it is original to the laptop.
Old 01-13-2015, 11:14 PM
pontiacpetey's Avatar
pontiacpetey pontiacpetey is offline
i had the same problem and an IT friend of mine told me to unplug the laptop and then turn it off. Remove the battery and then hold down the power button for about ten seconds to drain remaining power. Reinstall the battery and power up the laptop. It worked for me. Good luck.
Many men go fishing all of their lives without knowing that it is not fish they are after. ~Henry David Thoreau
