Old 02-24-2015, 02:18 PM
GregL's Avatar
GregL GregL is offline
Default ANOTHER OER Brand FAIL!
Hi Guys,
Rear upper trim panels for '68 standard interior. The fit and finish were so poor I can't believe they've ever sold any of these to anyone who kept them. The panels I received looked like they had been "re-worked" by someone at some point and then returned and re-shipped out to me. There were hammer marks on the under side of the upper metal panels, rivets holding the felts in place. I think the pics show how bad they are. I did contact Classic Industries (they ARE friendly and helpful) to explain the problem. They asked for pics and description of the problem. They pulled the remaining panels off the shelf to check for a better set but said all in stock panels looked as poor as the ones they'd sent me. They are sending a return tag and will refund my cost.
Now, can anyone recommend another supplier that you've used, for a good quality panel? I need complete, assembled panels, uppers only in black which shouldn't be too difficult to find. I would consider a good pair of used panels.
I just can't stress enough how poor the quality of OER Brand has been during my restoration process. I've spent upwards of $7,000 with Classic Industries on this car alone and the hit and miss rate has been about 50/50 regarding usable reproduction parts.
Best,
Greg
ID:	391225   Click image for larger version
ID:	391226   Click image for larger version
ID:	391227   Click image for larger version
ID:	391228   Click image for larger version
Old 02-24-2015, 02:57 PM
What about Legendary? Do they not make the panels for 1st gen F bodies?
Alternatively, do you still have the originals? I know you've made it clear that you want complete panels but I can tell you that it's not terribly hard to get the 'unfinished' panels and convert your original stuff over to them. Itis somewhat time consuming but probably no more than getting bad stuff, returing it, etc.
Here's a thread showing how it's done-
http://forums.maxperformanceinc.com/...d.php?t=763217
Old 02-24-2015, 04:49 PM
GregL's Avatar
I don't have the originals Greg, that's why I'm looking for complete panels.
Old 02-24-2015, 08:39 PM
transam1972 transam1972 is offline
Default DOOR PANELS
...I would wager that LEGENDARY makes one fine first -gen panel..I would/will check there website
Old 02-25-2015, 12:00 AM
I'm pretty sure they do. I was very pleased with everything I got from them.
Old 02-25-2015, 01:27 AM
A Schab A Schab is offline
I had to send the original metal for the rear panels to Legendary. They had new fronts but not rears the last couple of times thatI used them.
Old 02-25-2015, 12:06 PM
rtanner's Avatar
rtanner rtanner is offline
wow, thats bad
Old 02-25-2015, 06:58 PM
GregL's Avatar
So Legendary is out.
What I'm looking for is input or an opinion from somebody that has bought/installed panels they are satisfied with.
Old 02-25-2015, 07:58 PM
400 4spd.'s Avatar
This doesn't directly answer your question, but I may have a solution. If you can locate some originals from another F body, Al Knoch interiors in Texas will recover them for you. They specialize in Vette's but also do F-body pieces. They recovered some for a '68 Firebird we are restoring.
And I will add that I buy nothing that is OER brand if there is an alternative.
Old 02-25-2015, 08:50 PM
GregL's Avatar
Agreed on the OER. So what did Al Knoch charge and how was their turn around time?
Old 02-25-2015, 09:38 PM
400 4spd.'s Avatar
Less than 2 hundred for all 4 rear pieces. Add shipping. Turn around was about 2 weeks. Call and speak with Lisa. Tell her Steve at Barr's Restorations sent you.
Old 02-25-2015, 09:53 PM
Toms bird Toms bird is offline
would the 68 and 69 rear panels be the same? I've got a extra set that need recovered if you need them.
Old 02-28-2015, 09:46 PM
GregL's Avatar
Thanks for the offer Tom, but I've just found Year One offers them complete for $239. I'm going to go that direction.
Greg
Old 03-01-2015, 07:29 AM
frankyboy455 frankyboy455 is offline
Greg
Are you sure YearOne won't send you those same OER panels ?
Old 03-01-2015, 04:09 PM
GregL's Avatar
That was the first question I asked. They use a different manufacturer, PUI.
