Old 03-22-2015, 04:31 PM
GtoBrian's Avatar
GtoBrian GtoBrian is offline
Default Timing Question
Just test fired new motor, its a 1968 400 in a 68 Grand Prix, original 16 heads. I installed a Summit 2801 cam and being a 68 motor i set the timing set to fire at the number 6 position and set distributor in as such, fired right up and broke the cam in. My question is when hooking up the timing light do i need to attach the timing lead to the number 6 plug or can it be attached to the number 1 plug, just having a brain fart and cant find any info. Thanks for any help.
1969 Judge, Matador Red, Black, RAIII 4Spd, Owned 33years
1974 LeMans GT Honduras Maroon, 3 speed stick 350 2brl.
1963 Catalina 389 Black with Burgandy Ventura interior SOLD
1970 GTO Pepper Green 400 YS auto Factory A/C 56K orig miles
Old 03-22-2015, 04:37 PM
Both the #6 and #1 plug work exactly the same for setting timing.
Using the #6 plug is easier since it's on the same side of the engine as the timing marker on the front cover, less chance of getting the timing light wires tangled in the fan or belts.
Old 03-22-2015, 05:13 PM
GtoBrian's Avatar
Thank You very much b-man that is exactly what i was looking for.
