Old 03-23-2015, 06:11 PM
machota100 machota100 is offline
Default Looking 1978 trans am metal vacuum line
The line I'm looking for is the line that goes across the front of passenger side of the engine. It bolts front of the engine and the thermostat housing and looking four blue 4 hose ported vacuum switch. See pic thanks manny Click image for larger version
Old 03-26-2015, 11:45 PM
bowties427 bowties427 is offline
Starting at post 241...On the vacuum switch.
http://216.178.81.108/forums/showthr...755425&page=13
http://www.ebay.com/itm/301249077287...%3AMEBIDX%3AIT
Is the line your looking for goes over to the charcoal canister part way then connects via vacuum hose and on the other end connect to the carb. If so I may have one but no promises.
Old 03-27-2015, 05:11 AM
Thanks for the info on the ported vacuum switch. I have a ac delco replacement its white so i was going to attempt to paint it if i couldnt find the right one. That is the line im looking for. If possible can you send a pic if you can locate yours. Thanks
Old 03-27-2015, 05:12 AM
Old 03-27-2015, 08:31 AM
cressy cressy is offline
I have a used switch which I don't know if it works , needs cleaning up.
Name:	switch # 1.JPG
ID:	393820   Click image for larger version
Name:	switch # 2.JPG
ID:	393821   Click image for larger version
Name:	switch # 3.JPG
Old 03-27-2015, 09:44 PM
roundportponchos's Avatar
Default switch
Does it have part number stamped on top?
Old 03-27-2015, 10:05 PM
How much for the switch
Old 03-28-2015, 08:33 AM
I don't see a part # on top.
I would like $25 for it which includes mailing.
Name:	switch pic 4.JPG
Old 03-28-2015, 10:17 PM
Looked on the old parts car today and the line is missing. Its like it didnt have one, it was a vacumm line from the canister up to the carb.
Old 03-29-2015, 02:37 AM
Ok thanks for looking
Old 05-03-2015, 12:53 PM
462-6spd 462-6spd is offline
You still looking for these parts, Machota100? I know I have the metal line and pretty sure I have the vacuum switch too. Off a '79 TA 400.
Gary
Old 05-03-2015, 06:38 PM
It took a little time but I found everything. Im looking for a mint set of camel tan seatbelts and a 4 speed center console now.
