Ok guys, possibly stupid question here, but before I go and start removing things I would like some input.
I have swapped out my TH 400 for a 200-4R. It is a little narrower that the TH400, so the linkage from the trans up to the steering column now hits my headers, and I cannot move the shifter through it's full range of motion. I have toyed with the idea of removing this linkage, but I know it is tied into the neutral safety switch on the column. If I remove this linkage, and anchor the column arm, what will happen? I am also looking at lengthening the rod that goes from the trans to the frame so that I can retain all of this linkage. Any 200-4R swap guys here? What did you do?
461 Cu. In. Pure Pontiac Power: 1969 Pontiac GTO - Back On Top - Popular Hot Rodding Magazine |
On my Turbo 400 to TKO swap I simply made sure the column arm was in the park location. No issues with it.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
Backup lights and neutral safety won't work. I think they are still located on the bottom of the column.
be a simple...kinda man. |
I used an aftermarket shift rod set up when I did a swap into a 70 Suburban. Worked out well for me. Perhaps it will be something that will work for you. There are less expensive versions available from other manufacturers
http://www.summitracing.com/parts/lok-aca-1800
1961 Corvette 4spd. 1969 Chevy K5 Blazer - currently restoring |
