| 93-02 Transmission Tech Automatic or Manual trans tech |
06-17-2015, 12:47 PM
Keisler TKO 600
I just read something about problem with missing 3rd gear , anybody have info on the shift finger upgrade and rod ?
73 GTO 455 TKO 600 3.90
08-11-2015, 12:05 PM
My son is having a problem keeping his in 4th also. Would like to know too.
08-11-2015, 12:28 PM
The problem as I have found if from OLD muncies shifters!When go go for 3rd from 2nd you need to just go straight but the tendency is to push too hard toward 3rd and you sometimes hit the "taint"!Taint 3rd and taint 5th.I have thought many times about trying to come up with a 5th-rev lock out.Tom
08-11-2015, 01:30 PM
Yup. Once I "trained" myself to calmly go for 3rd I haven't had a problem going straight up from 2nd.
Popping out of gear is a whole separate issue, that I've never had.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
08-11-2015, 03:26 PM
I have owned 3 Tremics and have never had a pop out of gear issue.Tom
10-05-2015, 02:58 PM
The unloaded gate is the 3-4 gate. Just push forward and it will naturally go into the 3-4 gate. I learned this while testing Vipers at work. You almost don't want to think side ways....just forward.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
10-06-2015, 12:21 AM
Over a certain rpm and power the tko is impossible to get into 3 with out granny shifting. The carbon fiber syncro and brass shift tabs will help. Just sold my tko 600 due to this. Went a different route for now. The tranny was awesome when I only had 450 h.p. and was shifting at 5500 rpm.
01-29-2016, 01:17 PM
Well its getting a stage III kit installed, should fix it.
02-26-2017, 06:10 PM
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
