Old 07-20-2015, 10:46 AM
pggto's Avatar
pggto pggto is offline
Default Restoring a Build Sheet
What is the best way to clean or restore a build sheet? Mine has a lot of dirt and some rust on it. I've brushed some of the dirt away with a paint brush, but the paper is pretty brittle. Thanks
Name:	71 Build Sheet.jpg
Old 07-20-2015, 11:09 AM
marxjunk marxjunk is offline
if its brittle you are in trouble...if it where me, id have it scanned...and put it in a sleeve and leave it alone..use a sleeve dont laminate it.
then play with the scan, run it thru some photo software and clean it up.
Messing with the build sheet raises eyebrows when you try to sell..keep it as you found it. You can have a repop sheet made from your scan.
No one is looking for a perfect clean buildsheet..to me..i like what you have more than a nce clean legible piece.
I do think, if it black with tar and almost not legible..then doing something isnt a big deal..but..every one wants to restore them, and it takes away form the credibility of the sheet.
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 07-20-2015, 03:01 PM
Can you read the dealer name?
(and address?)
Someone with Photoshop experience may be able to get the buildsheet to be clearer.
(I'm not one of them )
Old 07-20-2015, 10:22 PM
pggto's Avatar
(and address?)
The dealers name is Bucks Motors, 90? W 2nd, Gillette, WY
Old 07-20-2015, 10:24 PM
pggto's Avatar
I would like to be able to clean the dirt off without damaging it, I can read it through the rust.
Old 07-20-2015, 11:00 PM
find a museum in town. Ask them who restores their documents, its cheap and does wonders...
Mark..
The Goat whisperer
Old 07-21-2015, 08:17 AM
Thanks for the info!
There was a thread a long time ago on PY about cleaning them.
But I could never find it.
HFR maybe can?
I know to never use water on it.
It will destroy the paper.
Old 07-21-2015, 06:04 PM
Held for Ransom's Avatar
Do a search for lacquer (or laquer) and build (or buildsheet) you will find some answers. I think this one has worked the best for me...
http://www.forums.maxperformanceinc....d.php?t=383828
Old 07-21-2015, 06:30 PM
Alvin's Avatar
Alvin Alvin is offline
Lightbulb
I'm pretty basic & old school @ buildsheet handling: photo copy it ASAP and leave the original alone in a protected sleeve away from sunlight. Have read that if exposed to common UV daytime lighting, original print will fade out and paper can disintegrate.
Old 07-21-2015, 08:38 PM
thepontiacman's Avatar
I have used Q-tips to very carefully remove dirt enough to be able to read it. scan it and print. May also use photo software to make it look better.
After I have gotten it where I can read most of it or at least most important info., I laminate it to preserve what is still there.
There is only so much you can do.
At least you can get a PHS on it. That helps with info.
Old 07-21-2015, 10:30 PM
Thanks, Mike!
That's the one I was thinking of.
Old 07-23-2015, 10:30 AM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
I found mine if pretty good shape. Left it on a work bench and a week later the light exposure made the ink fade away to nothing. I'd love to find a way to make it legible again. Scan it right away, store the original in a plastic sleeve and keep it in the dark.
http://www.pontiacpower.org/
Old 05-23-2016, 08:23 AM
pggto, did you ever get the sheet clean?
Old 05-24-2016, 06:13 AM
HJones1313's Avatar
HJones1313 HJones1313 is offline
Send a message via Yahoo to HJones1313
I put mine in an 8 x 10 frame, untouched and as I found it. Looks kinda cool that way.
"GTO......Gas, Tires and Overdraft"!
'70 GTO convertible, 434, 4-speed
Old 05-24-2016, 12:06 PM
pggto's Avatar
No I did not. I looked for a local place that restores documents but I didn't find anything. I currently have it in a plastic sleeve in a folder to protect it from the light. I would still like to get it cleaned up and scan it, then leave the original in a safe place. I might try the lacquer thinner yet.
Old 05-24-2016, 12:15 PM
pggto's Avatar
You might want to keep an eye on the print. Others have stated that the light will fade the print. But I agree it would look pretty cool framed.
