Old 07-21-2015, 07:22 PM
Check6 Check6 is offline
Default What is the correct 4 barrel carb on a 66 GTO 389
Looking for the correct 4 barrel carb on a 66 GTO. Holley, rochester, Carter????
Old 07-21-2015, 08:24 PM
Old Tin Indian's Avatar
Old Tin Indian Old Tin Indian is offline
Carter AFB
my favorite place in the world
a nice smelly garage
Old 07-21-2015, 09:37 PM
Jeff Hamlin's Avatar
Default On a 1966 GTO
X2 on the Carter AFB.
In '66 the OHC 6 with Sprint/Sports package was the only model to get the all new Q-Jet.
GTO didn't see it until '67
Old 07-21-2015, 09:38 PM
Originally Posted by Old Tin Indian View Post
Carter AFB
4041S - Manual trans with A.I.R.
4033S - Manual trans
4034S - Auto trans
4030S - Auto trans with A.I.R.
Here's a pair of the 4034S AFBs on a repro 'bathtub' tunnel ram. These carbs are rated at around 575 CFM each.
Old 07-21-2015, 09:42 PM
are you looking for one?
Old 07-21-2015, 10:31 PM
Thanks, for the quick reply. Mine has the Carter AFB so I guess I have the correct carb. I'm new to Pontiacs and GTO's. Just curious Here is a picture of my car Where would the carb number be located?
Old 07-21-2015, 11:11 PM
67Twistytee's Avatar
67Twistytee 67Twistytee is offline
Nice car! And welcome.
The '66 guys will weigh-in, but the carb should have either a metal tag on the right rear under the air horn (drivers side) or a stamp on the left front of the throttle body near the idle screws (possibly both stamp and tag). Should be 3-4 digits followed by an "S" if it's a Pontiac AFB.
Andy
North Carolina
1967 GTO SG over Parchment / mom original owner / sold in '78 / found 35 years later
