Old 08-24-2015, 12:28 PM
conceptfab conceptfab is offline
Default got some dyno time in!!
That torque tho!! I was a bit astonished at the numbers but I was happy to be king of the torque, even over the hopped up cummins and agr twin turbo 5th gen Camaro. Here are a couple pics and the video is the first post at https://www.facebook.com/ConceptFab2006
ID:	406355   Click image for larger version
Old 08-24-2015, 01:16 PM
mechanickeith's Avatar
Am I reading the torque correctly??? 746 Lbft!! @ 3650 rpm?? WOW!!
544 Hp @ 4750 rpm
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 08-24-2015, 02:30 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Nice! Hairdryers rule!
Old 08-24-2015, 05:35 PM
Macho78's Avatar
Macho78 Macho78 is offline
Nice #'s, crazy torque!
78 Macho T/A #123 [email protected] on motor [email protected] w/190 shot.
Old 08-24-2015, 08:16 PM
er455 er455 is offline
Default Boost
How much boost hp looks low unless boost was low
Old 08-24-2015, 10:34 PM
JSPONT's Avatar
Stock 389, small hyd. cam (2802) @ 4600 ' elevation. Stock 6x head for what it is at 9 psi that is nice! That power is to the wheels.
Old 08-25-2015, 11:19 AM
yup jspont got it right!
Old 08-25-2015, 03:15 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Crazy the power you can make with a stock engine!
Congrats, have fun.
Old 08-27-2015, 07:35 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Does the elevation really matter with a boosted application?
Impressive numbers.
Old 08-27-2015, 08:22 PM
Sure it does.
N/A it would be a huge difference, but being boosted it can make more HP, just not as much as if it was at sea level or the North East Coast.
Old 08-27-2015, 08:31 PM
ponjohn's Avatar
I completely understand that elevation has a huge effect on N/A.
But this is the turbo forum..
Old 08-27-2015, 10:57 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Impressive numbers.
Yes, it does. Just as much as it does with NA. I've learned that doing my blower conversion. The air quality numbers are critical to a safe and powerful tune. The difference is in a boosted situation, you can always (theoretically) increase the air input to compensate for "bad" air, something you can't easily do in an NA application.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 08-28-2015, 10:47 PM
My friend with a diesel suburban shop truck would like your numbers! Not bad at all!
Old 08-29-2015, 12:14 AM
v869tr6's Avatar
746, with a stock 389, did he mention 746, with a stock 389, LOL and that's at the wheels!!!
Old 08-29-2015, 12:10 PM
At only 3650 RPM!!! Getting that hooked up ought to pin him in the seat pretty hard! Proof you dont need long stroke to make big torque lol!
Wonder how much better a more turbo specific cam would work.
Old 08-30-2015, 02:49 PM
Fast 69's Avatar
Fast 69 Fast 69 is offline
Impressive torque! What turbo?
Old 08-30-2015, 04:48 PM
70 bird's Avatar
70 bird 70 bird is offline
Very nice numbers!
Old 08-30-2015, 10:39 PM
69FIREBIRD76MM's Avatar
Default dyno test
Are you planning on running it at the track?
Old 09-01-2015, 01:49 PM
Its got an old school TV7101 that I bought from Jeff on Pontiac zone. Its just a super simple combo that I really figured id blow up with the cast pistons. I am slowly building a pretty bad 400 that I want to make some crazy but reliable numbers with. Its a roller set up, ported rpm heads, etc.. This engine did however many years in the original car, then 17 years in a street rod, then sat for another 8-10 or something, then I got it and did this haha. And yes I went to the track but I didn't pass tech due to no cutoff switch and battery box. The tech took one look at the engine and that turbo and looked at me and paused. Then he said "Yeah. You'll wanna go ahead and get a fire suit and a cage while youre at it" and the other 2 or 3 three guys got a little upset with him and started questioning him "so.. youre not gonna let him run? Really? Come on.."
