Old 09-22-2015, 06:48 PM
hdpontiac hdpontiac is offline
Default 10 bolt rear end
im looking for a limited slip unit for a 10 bolt 323 but on the wanted ad on this forum there is a member that took the unit out of a 355 10 bolt rear end but we are not sure if it will fit the 323 any help will be appreciated
Old 09-22-2015, 07:10 PM
A carrier from a 3.55 isn't going to fit. The Low ratio Pontiac 8.2 carrier fits:
3.36, 3.55, 3.73 (aftermarket), 3.90, 4.10, 4.33... 5.57
Mid ratio carrier fits: 2.93, 3.08, 3.23 Pontiac 8.2 10 bolt gears.
Most common Pontiac 8.2 gears including all aftermarket Pontiac 8.2 gears use 3/8 RH thread ring gear bolts. Very late '69 model Firebirds and '70-72 A & GP Pontiac 8.2 10 bolts used 7/16" thread LH thread ring gear bolts. Needing the later style Safe-T-Track carrier, can have the ring gear bolt holes opened up on an earlier style low ratio carrier or on a new carrier.
Old 09-22-2015, 10:40 PM
What year did the carrier come out of?? I went from a 3:08 to the 3:73's that are in my car right now. Mine is for my 73 GTO with the new style carrier with the bigger axles & the 8.5 carrier.
Old 09-23-2015, 11:25 AM
AG's Avatar
AG AG is offline
Different animal, not an 8.2 diff.
Old 09-23-2015, 01:16 PM
ponyakr's Avatar
ponyakr ponyakr is offline
http://www.justdifferentials.com/AG5...5420114-hp.htm
Old 09-23-2015, 05:25 PM
I understand it's not an 8.2 but again I ask what year is the rear end & what did it come out of. As I said if it's the newer 8.5 that is in the cars from 73 up you can swap the gears to the 3:23's into the carrier from the 3:55's as it will support it. But if it's an older carrier rear end then it may not work, but again let me know which year & rear end it is if you know. ???
Old 09-23-2015, 05:40 PM
It's a '69 10-bolt 8.2 rear he's asking about.
http://forums.maxperformanceinc.com/...d.php?t=780178
Old 09-23-2015, 07:24 PM
Red face
So true!
Reading comprehension seems to again be a problem here.
