Old 11-06-2015, 08:31 AM
sdbob sdbob is offline
Default Need to redo brakes on SD. Parts questions
Need to redo entire brake system on 74 SD. Whose parts are quality? What fluid are guys using? Thanks Bob.
Old 11-07-2015, 09:40 PM
SMW SMW is offline
I used an AC Delco master cylinder. I would recommend you stay away from Cardone. I went through 3 new master cylinders in 2 weeks before I went with the AC Delco. I use Prestone Dot 3 brake fluid. I have had no problem with Wagner brake parts.
Old 11-08-2015, 04:29 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Replace the 3 rubber brake hoses. Delco made in china available at rock auto.
Dot 3 was factory installed in all makes and models for decades. I don't see any reason to change.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 11-08-2015, 03:38 PM
I figured everything made overseas.That's why I asked. Probably go to local NAPA.
Old 11-27-2015, 08:37 PM
njsteve's Avatar
njsteve njsteve is offline
Bob, does your car have the original master cylinder with the two bleeder screws? If so I would send it out to White Post Restorations to have them rebuild and sleeve it if necessary. They did an awesome job on the original master cyl on my car. They can also do the rear wheel cylinders, too if you are looking to keep all your original pieces intact.
http://forums.maxperformanceinc.com/...itepost&page=9
