Old 12-03-2015, 01:23 PM
Default Need help with new 49-68 rear disc setup
We are redesigning our 49-68 Pontiac/Olds rear disc setup. We may be able to do this as a drum-in-hat type emergency brake setup instead of a integral caliper style as before. As you know the early Pontiacs had a different style of cable retention to the backing plate as shown in the Buick pic. What we need help in is dimensions where the Pontiac cable mounts to the drum backing plate. If we know this the existing or repop cable can be used if slightly modified. Pix of the Pontiac backing plate are great too...
This is the version for the 68-81 F body. We also have it for 64-72 A's
Name:	1955Buick rear e-brake cable mount.jpg
Old 12-03-2015, 04:28 PM
63gpman's Avatar
63gpman 63gpman is offline
I could mail one to you if you want for the cost of shipping?
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 12-03-2015, 04:48 PM
Thanks, I will keep that in mind. Does yours look roughly the same as the pic above?
Old 12-04-2015, 11:35 AM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
So are you asking for dimensions from ANY year backing plate between 49-68? I have some 1965 backing plates loose that I can easily measure.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
Old 12-04-2015, 12:16 PM
Yes, the more the merrier - usually this kind of stuff does not change much but one never knows.
Old 12-04-2015, 01:58 PM
Doug Doug is offline
Thumbs up backing plate
Here is what I believe is a 1962 big car. The "hole" for the cable is 2 3/16" down and 3" forward of the hub centerline.
The part number on the plate reads:
MORAINE
PRODUCTS
5456881-L
Name:	005 (600x450).jpg
ID:	414831   Click image for larger version
Name:	006 (600x450).jpg
Old 12-04-2015, 08:35 PM
pfilean's Avatar
pfilean pfilean is offline
So it looks like here was a design change between 61 (as I posted in the 61 forum) and 62 from a bolt in brake cable to one with a clip retained cable.
Old 12-07-2015, 05:37 PM
I think if the offer still stand we will take it. Please email direct:
[email protected]
and will arrange payment.
Mark
Old 12-23-2015, 06:36 PM
New setup on the test bench. We found machining the bracket for bearing clearance was not an attractive option here so we are adding a pair of bearing shims to retain the wheel bearing securely. The rotor is from an Impala, and uses the drum-in-hat style e-brake. We improved this by utilising a cheaper, larger caliper and also a adjustment screw mounted that allow external fitment. Hose routing is pretty simple as shown, with a welded tab to securely retain the line - no zip ties.
Old 12-23-2015, 07:12 PM
60man's Avatar
60man 60man is offline
Thanks for your products Scarebird.
ECM member.
MANDRA
Old 12-23-2015, 07:13 PM
team1360 team1360 is offline
Nice! Look forward to snagging a set to match my front kit.
Old 12-25-2015, 06:16 PM
AROWHED's Avatar
Looking good...I'll be glad to have the drum e-brake option and ditch the TA calipers. Any estimate on price and availability?
