Old 04-11-2016, 11:00 AM
rohrt rohrt is offline
Default 68 Ram Air pan setup
Was thinking of pulling the trigger and finally getting the Ram air setup this summer.
I see the "Parts Place" is selling a kit. They would be my last choice. Anyone use them?
Who else sells an all metal kit? Is Warpath Restoration still around?
Old 04-11-2016, 11:18 AM
68tpls400 68tpls400 is offline
I bought mine about 5-6 years back. I'm not 100% sure, but more than likely was from the Parts Place. Everything fit well.
Old 04-11-2016, 12:25 PM
Inogame Inogame is offline
I found a set on Ebay that was much more reasonable than Parts Place (see price update note below). I was sent that way by someone on a Pontiac page on facebook. Out of Ohio I believe.
It was substantially cheaper then any of the catalog vendors and the only thing not included were the open hood scoops.
Here is the link:
http://www.ebay.com/itm/1967-1968-FI...item1a04768fea
While I was looking for the link I see the Parts Place is now offering the same kit with the scoops for the price of the one I bought. It wasn't that way 6 months ago, but I guess that's what happens when a new player shows up.
Anyway, my set fit well. The pan shipped as raw metal so I painted it, but that was no biggie to me.
Now that the prices are the same as TPP it's probably not the way to go, but I thought I'd share anyway.
Old 04-11-2016, 12:30 PM
I think those are all made by Goodmark. My Parts Place (likely) was $450 about 6 years ago, and came with aftermarket hood scoops. I sold the aftermarket scoops (don't fit OEM hoods), for $60. So was into my setup for under $400.
Most any dealer that sells Goodmark should be able to get these.
Old 04-11-2016, 12:34 PM
Warpath is selling on eBay now. I just did this to my '68 GTO and got a substantial savings buying the parts seperately from a PY member who has a connection with Warpath. I already had a set of open scoops but got everything I needed from him with the exception of the wing nut, filter element and one of the foam pieces. Even after buying those parts from our host, I probably saved $150 or so over buying the kit.
Here's the thread I started in which I was asking basically the same question as you- http://forums.maxperformanceinc.com/...ght=68+ram+air
Old 04-11-2016, 01:07 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
I got my setup from the parts place ebay store last year and everything seems to be pretty good. I had no problems with the purchase what so ever. Now I just need to get them and my hood painted so I can actually get everything installed.
http://www.ebay.com/itm/1967-68-Pont...item4cf99f8faa
67 Firebird Convertible
Old 04-11-2016, 02:29 PM
Thanks for the info. Good to know the scoops don't fit on the stock hood.
Old 04-11-2016, 09:40 PM
brians's Avatar
brians brians is offline
Been stamping the upper and lower pans for about 15 years in upper Ohio. I’m probably one of the only fools out there that would spend the amount of money I did on large forming dies for such a small run of pans but just love the 68 RA cars. Used two of mine and Barry Martin brought a couple to Norwalk to get good dimensions off of.
Made the correct foam seals only because I needed them for my 68 FB and they were never the right shape. (They are not in any catalog only sell them directly)
Parts Place use to purchase the pans from us but then decided to take them and send them to China to duplicate. On a good note, for some reason China punched extra holes in the upper pan so it is easy to tell at a show if they are ones imported by Parts Place.
Rohrt – If you are interested in a kit, shoot me a pm.
If you are interested in saving some money and doing some strip and painting, have a few lower pans that the paint came out crummy.
Brian
“If you ain't first, you're last” - REESE BOBBY
Old 04-12-2016, 09:08 AM
Brian
And right there is one more reason for me to hate the parts place. I will be sending you a PM.
Old 04-12-2016, 09:36 AM
And if you read my post, you now know who I got mine from. If you click the link in my post, you'll find pics of the actual parts I recieved from Brian.
Old 04-13-2016, 09:21 PM
azbirds's Avatar
azbirds azbirds is offline
Talking
Been stamping the upper and lower pans for about 15 years in upper Ohio. I’m probably one of the only fools out there that would spend the amount of money I did on large forming dies for such a small run of pans but just love the 68 RA cars. Brian
So, are you going to expand to the 69 RA pans to take advantage of that press?
Old 04-13-2016, 11:28 PM
Donovan Donovan is offline
I also got mine from Brian.... excellent.
Old 04-14-2016, 12:20 AM
brians's Avatar
NO WAY
I should have just took that money and bought a 69 TA back then. Would have been money ahead right now and had much more fun.
(Well actually would have been a blue 70 TA 4sp )
Old 04-14-2016, 06:46 AM
The Boss's Avatar
The Boss The Boss is offline
Oh there are plenty of reasons you can do that - I think everyone here has one (at least) of their own!
I have an original pan set for my 68 but have Brian's foam.
And go racin' in the street.
Old 04-14-2016, 09:20 PM
I may have bought upper and lower foam for my Firebird from you on Ebay? I can say, its the best. After 2 tries from NPD, their foam was CRAP.
Bill Nye.
Old 04-14-2016, 09:38 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
got mine from Brian as well and they are excellent. Just ordered a replacement upper foam as well.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 04-21-2016, 10:16 AM
The parts showed up a few days ago. Thank you.
Have not had time to open the box yet.
A few things I need to figure out is how to glue the foam down.
How to grow some balls to cut my scoops open
What needs cut on my 400 hood.
I saw on the Firebird forum about cutting some bracing on the hood.
Old 04-21-2016, 12:40 PM
ANDYA ANDYA is offline
On my car I glued down the foam seal with yellow weatherstrip adhesive. For opening the scoops I purchased a spare set at a swapmeet and opened them. As far as the bracing under the hood I decided not to cut anything. The upper ram air pan will still fit and enough air will still get in.
Old 04-21-2016, 02:33 PM
I was lucky enough to find an open pair at a swap meet for $20. When I had my car painted, I had both sets of scoops painted with it.
I used black weatherstrip adhesive for the upper pan but I used refrigerator magnets to secure my lower foam to the pan. You only need it to stay in place when the hood is up. It ain't going anywhere when the hood is down!
I did cut the bracing on my hood because I wanted to actually get the upper pan to fully seal to the underhood. I wanted all carb air to come in from the outside. Again though, this is a GTO so you guy's mileage may vary as they say.
You all are actually in luck that the instructions included in the kit are for a Firebird.
One more tip- Make sure you glue the upper pan seal to the outer perimeter of the pan. If it's too far inboard, the foam will be visible looking into the scoops, partly blocking the opening. I had to adjust mine a couple of times to get it where I wanted it, completely out of sight.
Old 04-21-2016, 03:45 PM
I have a 2nd hood with open scoops but wrong color. I'm thinking once I put the pans on they are not coming off so I might as well just cut them open rather then paint up my other scoops.
What do you guys do about rain and washing the car? Do you plug them or anything?
Another dumb question but can the engine breath if you plug the air scoops or is that the only source for air?
Any pics of the brace cut on the hood?
How did you do the refrigerator magnets on the foam?
