WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 1993-02 Firebird/Trans Am Owners > 93-02 Engine Tech
93-02 Engine Tech LT1 and LS1 motor heads unite!
Old 07-19-2016, 10:49 PM
lugnutx2 lugnutx2 is offline
Default Is this an opti spark symptom?
Lately my 94 T/A has been taking an extra couple of seconds to fire up. I started it last week and it died in the garage and wouldn't restart. Today it started right up. I discovered that the previous owner replaced the water pump and then the computer, so he must of had some problems, but failed to tell me at the time of the sale. I'm sure he got the opti unit wet when changing out the pump. Will a bad opti run sometimes and then leave you sitting the next, or do they die and not restart? I have no experience with this setup.
Old 07-20-2016, 01:39 PM
amcmike's Avatar
amcmike amcmike is offline
Yes Optispark problems can cause that. Worst idea GM ever had.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 07-20-2016, 02:15 PM
quicksilver97ta's Avatar
Well everything get blamed on the opti on an lt1 car, and while it could be, I would absolutely check your fuel pressure before buying any parts. Your symptom sound more like that for a first suspect.
Old 07-20-2016, 10:51 PM
I'm not to wild about spending $500 for an MSD opti, so I'll sure check the pressure first.The fuel gauge reads slow, so maybe there is something going on in the tank? This car sat indoors for years and was seldom driven.
Old 07-21-2016, 08:38 AM
I remember my gauge sweep was maybe a little slow but more importantly I have run out of gas when the needle was a hair above the E line. My pump died with 60k something miles so it happens.
Old 07-22-2016, 08:31 AM
Did the new pump and sender fix the gauge sweep?
Old 07-22-2016, 10:30 AM
Sirrotica's Avatar
My 97 T/A also ran out of gas when it was still indicating 1/8-1/4tank.
I had a random problem with the engine laying down and barely running intermittently, then it would straighten out and run fine. However the car caught fire under the hood due to a leaking fuel line before I solved the intermittent problem.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 07-24-2016, 05:40 PM
The speed of the sweep? Didn't notice. The range? Never let it go below 1/4 tank.
Featured Vendors
Advertising Info
