Old 08-04-2016, 03:00 PM
ilo ilo is offline
Default 68 Vinyl top clip placement
Just wondering if anyone can post pictures of the placement of all the different types of clips for the the vinyl tops trim? I got my car with the top removed long ago and I want to put it back on.
Any help would be great
thanks
James
James Aiello
1968 GTO H.O. 4spd
Old 08-04-2016, 03:56 PM
dataway's Avatar
dataway dataway is offline
I'd like to see that info too.
Old 08-05-2016, 04:11 PM
ilo ilo is offline
Maybe some photos showing the clips in there original positions..
thanks
James Aiello
1968 GTO H.O. 4spd
Old 08-06-2016, 11:39 AM
gtohunter's Avatar
gtohunter gtohunter is offline
Default Vinyl top chrome trim
These are original nails and holes but I don't have dimensional info. Lay the trim out to where it fits well, and just find center of trim. Pins don't need to be dead on spacing wise, but holes need to be pretty close in terms of their locations!
If you could scare up an old set of pot metal corner pcs., just cut off the studs, and drill a small hole through them, and this would allow you to mark the pin locations under the corner pcs.??
The one pic is just showing the chrome loosely attached.
ID:	434236   Click image for larger version
ID:	434237   Click image for larger version
ID:	434238   Click image for larger version
Jimmy M
68 GTO
Old 08-09-2016, 11:01 PM
dataway's Avatar
If you could find someone with a vinyl top and a body getting ready for paint you could probably make templates to match everything up.
Old 08-20-2016, 05:05 PM
Beige1968GTO Beige1968GTO is offline
Default 68 vinyl top clips
I have a 68 GTO that originally had a vinyl top that has not gone back on yet so I can take photos of the pin locations. Do you want me to post them here?
Ron
Old 08-23-2016, 11:31 AM
Ron
My opinion, it's always good to do that kind of stuff on the open forums so others can see it if they search it in the future.
By the way, the locations marked 'HOLE' on the photos above require the special trim clips that have a threaded stud to go through the hole and a trim nut to hold in place. The other end of course is made to fit into the trim.
All of the 'NAILS' or clip studs as I call them, require the regular snap on type clips. You have another special type clip that fits the trim on one side and inserts into a hole right at the corner of the rear quarter glass.
I may have some photos of the different type clips if no one else posts any.
Old 08-23-2016, 11:49 AM
ilo ilo is offline
All I have is a bag of clips and no way of knowing the location for each one... I should of had the guy take photos of disassemble for me.
I would imagine this information would be helpful for all GM a bodies from 68-72 or at least just the GTO/LeMans.
thanks
James Aiello
1968 GTO H.O. 4spd
Old 08-23-2016, 01:24 PM
Mine had already been removed too and when I did some extensive metal replacement due to vinyl top rot, I had no idea where everything went. I actually had to visit the junkyard over a period of time to get a consensus of how GM did it to the A bodies in the late '60s.
The style of moulding clips varied from car to car but the attachement method remained pretty constant.
Old 09-02-2016, 08:15 PM
Default Does This Help?
Are these photos helpful? (The silver item is a yardstick.) I can send the full size images if you send me your e-mail address, or let me know what measurements, or photo angles you are looking for.
Ron
ID:	435988   Click image for larger version
ID:	435989   Click image for larger version
Old 09-03-2016, 10:20 AM
ilo ilo is offline
thanks that will help... I can use what you sent..
James Aiello
1968 GTO H.O. 4spd
Old 09-03-2016, 05:43 PM
Default Not a problem
Not a problem to take more photos- if you can't read the numbers on the yardstick I'll send you the full size images . . .
Ron
