Old 09-19-2016, 02:34 PM
STEELCITYFIREBIRD's Avatar
Default 1968 GTO clone
I am looking into purchasing a 68 GTO clone, 72 455HO/TH400 in it, PW and front disc brakes..
What are the problem areas on these cars?
What is different from a LeMans/Tempest to a GTO for that year?
Rear end different?
I don't know much about those year cars.
Thanks for any advice!
Old 09-19-2016, 08:07 PM
MD79TA MD79TA is offline
You are in the wrong section of forum. But your question is quite vague. Try 68/69 gto tech help section and you may get s reply.but you really need to do some home work . Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 09-20-2016, 12:01 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Make sure the rear end tracks correctly. the center frame section is flimsy. check for straightness. It could be rolled under. Put car on a drive on lift and inspect for rust or quality of rust repairs. Look for cracking bondo. Check rear window operation. Dont pay gto price for a clone.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 12-18-2016, 09:41 AM
moparcolt's Avatar
moparcolt moparcolt is offline
They rot around the window frames, lower front fenders core support especially under the battery.
Frames wereally a problem back by the suspension mounting points
Chris Collier
1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans
"There is no such thing as too much horsepower"
Old 12-18-2016, 11:41 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Rear end different?
The differences between Tempest, LeMans, GTO are basically trim for the interior (woodgrain dash vs. dk aqua) Outside the Endure bumper is probably the biggest difference from the chrome nose on the Tempest/Lemans although you could order the GTO with the chrome nose. GTO tail lights are different and of course badging.
The rear would be the same, 8.2 10 bolt single track is standard and limited slip is available in any model I think.
The best thing you can do is see it in person, ask to put it up on a rack as suggested above and drive it.
Good luck.
Old 12-20-2016, 03:32 PM
Rear glass channel and therefore the trunks rust on these cars. The lower corners of the rear glass opening have a perfect water retaining shape. Once that rusts through, the trunk is next. Also, at the base of the windshield where it's sealed to the dash. If it's a vinyl top car check it very carefully for soft metal under that. Especially around the rear glass, sail panels and drip rails.
Other than that, they rust in the same typical places as the rest.
