Old 10-24-2016, 10:15 PM
Larry 400 Larry 400 is offline
Default glove box door spring ????
Does a 1968 Firebird have a glove box door spring to open the door??
If so where can I buy one ??
Larry
Old 10-25-2016, 12:17 PM
68400BIRD 68400BIRD is offline
Ames part number FA565G this is for a center console door.
Old 10-25-2016, 12:27 PM
There is a small spring on the latch. There is no spring to hold it open or closed. As far as I know, you need a new latch if the spring is missing.
Bill Nye.
Old 10-25-2016, 08:12 PM
The latch has a small spring that returns it to the up position when you release the button.
When the button is pushed is the latch supposed to stay in the down position till you close the door ??
Now when I push the button the latch releases but I'm holding the door closed by pushing the button. When I release the button the latch returns to the up position and the door is latched close. The only way to open the door is to pull it open while holding the button in.
So I guess the latch should stay in the open position till the door is closed. Correct ???
So I need a new latch ??
Thanks, Larry
Old 10-26-2016, 09:32 AM
Sounds like it is working correctly. But you might need to adjust the catch. The weight of the door alone should let it drop down. If you have to pull it down the latch is hanging up or the cam arm on the side is bent or dragging on something.
Old 10-26-2016, 11:17 AM
You dont have a problem, that's how it works.
Bill Nye.
Old 10-26-2016, 08:35 PM
Bingo, that is the problem. When I push the button it only disengages the latch about 80%. If I put slight pressure on the door it will open right up. So either my latch mechanism is worn and I'm not getting full travel or the catch needs to be adjusted.
Thanks for the help.
Larry
