Old 10-30-2016, 05:31 PM
66_Catalina 66_Catalina is offline
Default F body headers in 66 Catalina
Have the engine in and put the headers on today. $99 Summit headers for a second gen Firebird. After raising the engine up about 5 inches I could get them in place. They required some hammer love at the steering box and the passenger side rear A arm of all places. Other than that decent fit
Old 11-01-2016, 01:29 AM
66bonne's Avatar
66bonne 66bonne is offline
Good info.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 11-01-2016, 09:38 AM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
What Summit part number are those?
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
Old 11-01-2016, 05:36 PM
SUM-G9020. I bought them 2 years ago. I'm going to make a reflective heat shield for the steering box but I was surprised they didn't require a lot of hammer work. A couple of dings here and there and they went in. You'd think F body headers would fall into a B body but not the case. I'm hoping to get it started for the first time on the 11th. Hope it holds together. If it runs its on to brakes and trying to fab up a ford truck rear.
Old 11-01-2016, 07:42 PM
rustyrelic rustyrelic is offline
Is this automatic transmission? On the column or on the floor? I had always heard that no headers fit an auto on column for 65 - 70. True or no?
Old 11-01-2016, 07:47 PM
It's been an auto with floor shift since before I bought it at the scrapper
Old 11-02-2016, 11:38 AM
AROWHED's Avatar
Thanks for the info. Got any install pics..specifically the tight areas that required massaging the tubes?
Old 11-02-2016, 12:36 PM
Prior to hammer.
Old 11-02-2016, 12:40 PM
Drivers side
Old 11-02-2016, 03:17 PM
AROWHED's Avatar
Thanks again, 66...glad to know there is another low cost header option out there.
Would not have thought 2nd gen F body headers would ever work.
https://www.summitracing.com/parts/sum-g9020
Old 11-02-2016, 03:21 PM
Teej's Avatar
Teej Teej is offline
Hmmm... That's tempting... Especially since I haven't finalized the exhaust plans for my '66 wagon. How's the ground clearance?
Thad
1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver
1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!!
Old 11-02-2016, 04:20 PM
I'll check ground clearance when I get a chance. Seemed ok with 225/70/15s. I was hoping headers designed for a tight F body engine bay would easily fit a big B body. Plus I'm too poor for fancy manifolds or custom headers.
Old 11-02-2016, 05:42 PM
Even with a heat shield I may look at a power steering cooler as well.
Old 11-02-2016, 06:38 PM
Tucks up against where the floor would be. Doesn't hang too low.
Old 11-03-2016, 09:46 AM
mrrat1 mrrat1 is offline
Thanks for the info........our floors are very similar! LOL
Old 11-04-2016, 11:10 AM
I should get a chance to measure ground clearance today. I'll post the results after I measure.
Old 11-10-2016, 01:12 AM
scld1354's Avatar
scld1354 scld1354 is offline
Feeling too lazy to use the search function... What are some other low cost header options?
Originally Posted by lust4speed View Post
Welcome to the broken nipple club - I'm a charter member.
Old 11-10-2016, 08:28 PM
Got tied up the other day. I'll measure clearance and hopefully start it tomorrow.
Old 11-11-2016, 06:14 PM
5 inches of clearance with 185/65/14's on the front.
Old 12-19-2016, 02:43 PM
RonBurgundy's Avatar
RonBurgundy RonBurgundy is offline
Will these headers fit, with a little massaging, on a column shift car?
