Old 12-30-2016, 12:10 AM
STEELCITYFIREBIRD's Avatar
Default COMP 041 clones
51-314-4 http://www.compcams.com/Company/CC/c...csid=1210&sb=0
51-116-3 http://www.compcams.com/Company/CC/c...px?csid=6&sb=0
Anyone have any experience or insight here?
Old 12-30-2016, 02:12 AM
74Grandville 74Grandville is offline
No experience, but the 51-314-4 does not even look close to an 041. I'd go with the 51-116-3
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 12-30-2016, 06:59 AM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
The 51-116-3 is a very good cam. Makes good power and is very street able in a 455.
Old 12-30-2016, 07:14 AM
steve25 steve25 is offline
The first Cam is very much like a Crane custom ground roller that I used in my 455 over 30 years ago, other than my Cam had only …469" lift with 1.5s.
It ran very well with stock chambered 1971 #96 heads and pulled good vacuum even before I placed the Blower on top!
Old 12-30-2016, 07:25 AM
jamaca85 jamaca85 is offline
the 116 cam is with 1.65 rockers.the lift on the cam is abt 470 aprox with the 1.5 rockers. they should state that on the cam card somewhere.
1970 firebird, 468, e heads,
Old 12-30-2016, 11:33 AM
ponyakr's Avatar
ponyakr ponyakr is offline
That first cam is an XE series steep ramp cam.
If I wanted to run something similar to an 041 grind, but didn't like Rhoads lifters, I'd go with the Howards 410051-14, or back off to the Crower 60243.
https://www.summitracing.com/parts/h...w/make/pontiac
This Lunati is similar, but with a 110 LSA.
http://www.lunatipower.com/Product.aspx?id=1764&gid=279
vitamin c vitamin c is offline
I cant give you any comments really because I haven't run the car enough before doing a mini mechanical restoration, but the 74 SD I picked up late summer has the 51-314-4 in it. Test driving the car before I purchased it seemed as if it was short on bottom end power, and light on vacuum for the brakes. I will be finishing a tune up here soon and will be able to give some vacuum readings and such, but with winter here wont be able to drive it for some time.
Old 12-30-2016, 11:55 AM
Mill your SD heads .060" to get the comp up from 8.4 to near 9.3 and not only will your vacuum come up , but so will the motors power along with improved idle.
Old 12-30-2016, 12:46 PM
1968GTO421's Avatar
Just for FYI the Lunati 041 cam is this one:
http://www.lunatipower.com/Product.aspx?id=1755&gid=340
GTOAA--https://www.gtoaa.org/
Old 12-30-2016, 04:56 PM
With different lifts where the #'s are taken from, are these very similar cams on a tighter LCA or much different animals? I have no clue how to convert or if anyone has used the 51-314-4.
This is way beyond the scope of my ability to convert to comparable #'s, hoping for some more definitive differentiation.
The 51-116-3 looks to be a very viable 041 clone, the other ?????
Old 12-30-2016, 05:39 PM
Hillard's Avatar
Hillard Hillard is offline
If you are looking for a RAIV replacment cam the Melling SPC-8 is a direct replacement. The Crower 60919 is also a RAIV replacement cam and I've used it many times. It works great. https://www.crower.com/media/pdf/2008b/126-128.pdf. I think if you do a search on here you'll find lots of people like it. I'm curious though why you want it. What's your combination? Maybe something else would work better. Cubic inch? compression? headers? auto or manual trans? Converter? gear ratio? Street? Race? Street/strip? All of these need to be taken into consideration when picking a cam.
Old 12-30-2016, 05:45 PM
ponyakr's Avatar
Yeah, there are several vendors who sell their version of the 041 clone. Some of these are probably the same cam. Don't know who actually grinds their own cams.
http://www.ebay.com/itm/Engine-Camsh...3D252651405427
https://www.summitracing.com/parts/crn-969681
http://www.jegs.com/i/Crower/258/609...FW0BoCWAjw_wcB
http://www.edelbrock.com/automotive/...7157&submit=go
http://www.ebay.com/itm/Pontiac-Ram-...1Uwp5F&vxp=mtr
The Wolverine # was WG-1014. A quick Google search did not find anybody selling that cam. I read that Crane bought Wolverine. So they probably dropped that part number, in favor of the Crane version listed above.
http://ronspontiacpage.com/reference.../wolverine.htm
This is probably a good thread to list all the 041 clones currently available. So, if ya'll know of others, please post the links.
Old 12-30-2016, 05:48 PM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
The first cam 51-314-4, is the same cam that Half Inch Stud recently installed in his gto. Dont think he cares for it compared to the one it replaced.
Old 12-30-2016, 09:37 PM
Likely too much time off for the Holidays has me searching around the net more than I should. This "other 041" grind just caught my eye, as I have never seen or heard mention of it before.
What I am guessing here is comp pulled the LCA in 4 degrees and recommends installation 4 degrees advanced from that. Every thing else seems a difference measured in frog hairs?
So I surmise this is cam is intended to have some added low end torque over the tried and true, and beloved 041, at the expense of idle quality compared to the factory grind?
HIS is the lab rat on this one, a 455 with 48 heads!!
What CR does that work out t??
I'm over 11:1 in a 400 w/#48's.
Old 12-30-2016, 09:49 PM
ponjohn's Avatar
ponjohn ponjohn is offline
No it isn't.
The cams you speak of are XE274 XE284.
I'd consider the 60919. Many proven combos here with it.
Old 12-30-2016, 10:00 PM
NeighborsComplaint's Avatar
Originally Posted by ponjohn View Post
No it isn't.
The first one listed is a dual pattern with Magnum lobe profiles.
Old 12-30-2016, 10:08 PM
ponyakr's Avatar
No it isn't.
The cams you speak of are XE274 XE284...
The 51-314-4 is listed as an "Extreme Energy Drag" series cam. To me, that makes it an XE cam.
http://ronspontiacpage.com/reference-pages/comp.htm
Maybe this is an old, out of date CC listing. I have no idea.
It appears that this exact same cam is now listed as a "Magnum Muscle" series cam, instead of XE Drag. Don't know exactly when the name change came. ???
https://www.summitracing.com/parts/c...w/make/pontiac
The XE274 has 44 degrees difference between adv dur & @ .050 dur. The 51-314-4 has 48 degrees difference. They both look like steep ramp cams to me.
https://www.summitracing.com/parts/cca-51-224-4
The 51-116-3 has 61 degrees difference. That is definitely not a steep ramp cam.
Old 12-30-2016, 10:20 PM
Steve C. Steve C. is offline
Hydraulic-Magnum Muscle Camshaft / single pattern cam
http://www.compcams.com/Company/CC/c...csid=1210&sb=2
Not a XE cam.
Old information here:
Old 12-30-2016, 10:42 PM
I'm not trying to choose a cam, just looking for WHY and for WHAT outcome, with all the smart guys here someone has to have an answer for me. I'm vaguely familiar with the different lobes, listed in the back of the old catalogs, as I recall from a LONG time ago. http://www.compcams.com/Technical/Ca...terCatalog.pdf
Same lobes, shifted placement, or entirely different lobes?
THANKS!
Old 12-30-2016, 11:00 PM
ponyakr's Avatar
Originally Posted by Steve C. View Post
51-314-4
Not a XE cam.
I would not call that a single pattern cam, since the @ .050 dur is 5 degrees different. Also the 280 exhaust duration # might be a misprint, since it is listed as 288 in some places. Have no idea what the ACTUAL specs are.
https://www.summitracing.com/parts/c...hjkaArdm8P8HAQ
51-314-4 (280AH-10) HFT D 280 288 232 237 0.482 0.482
The intake lobe looks to be almost the same as the single pattern 280 Magnum--Grind #280H . But the grind number for the 51-314-4 is 280AH-10. Looks like a different grind # than the single pattern Magnum cam.
http://www.compcams.com/Company/CC/c...csid=1197&sb=0
