Old 02-17-2017, 01:38 PM
BMFGTO BMFGTO is offline
Default Remote mirror
Does anybody know how to replace the cables for remote mirror. I have a good mirror just need to replace remote control With cables.
Old 02-18-2017, 07:39 PM
What's wrong with them? Are they broken or just disconnected from one end?
Old 02-18-2017, 10:44 PM
Bet Winner's Avatar
Bet Winner Bet Winner is offline
Here is a related question if BMF does mind me asking. I have an NOS mirror on my car so all the chrome is perfect, but I would like to send my original to be chromed.
Does anyone take these apart and chrome them? I am not sure that I can successfully get it apart and back together and have it as new. If someone does this, they would probably be able to replace the cables.
My Wife: "I thought I married a sophisticated business man, but what I actually got was a redneck fisherman with muscle cars."
Some people know all of their rights, but none of their obligations.
Old 02-18-2017, 11:00 PM
Most NOS remote mirrors you see on eBay in recent years are incorrect, they are the version that was used on post cars that still had vent windows. When you install them on hard-tops or convertibles they fit but they look weird because they are tilted with way to ok much angle because they were meant to be set farther back on the door behind the vent window.
You can spot these post sedan mirrors because unlike the correct hardtop-convertible remote mirror that had studs to mount it to the door the post-vent window version uses the bracket and set screw like the non remote mirror.
Old 02-19-2017, 12:14 AM
Bet Winner's Avatar
I understand. I purchased mine from Pontiac in the early 80's. It is entirely correct except for the date code in the glass.
Old 02-19-2017, 05:37 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
I took mine apart and sent parts out to rechrome. Was a lot of work just like anything else done with these cars. One thing I've noticed with the remote mirrors I have is the screw that holds the mirror to the base has two different designs available and are not noticeable from outside appearance and parts are not interchangeable.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 02-20-2017, 10:58 AM
When installing I had to remove cables from control because wouldn't fit
In hole of door and now doesn't work right. Just wondering if there was a secret to puting these cables back together
Old 02-20-2017, 11:32 AM
GOAT WHORE's Avatar
The ends of the cables were color coded, did you mark their location and put back together in the same manor?
Make sure the cables are seated properly also. When I put mine together the first time it did not work smooth. Went and made sure all the cables were seated right and it is as smooth as butter now. Also might want to clean and lube all the cables.
Old 02-21-2017, 12:34 PM
Thanks I will give it a shot!
