I currently don't have screws in my wheels and have noticed that they have moved a little bit. What do you guys use instead of screws? I just hate to start putting holes in my wheels if I don't have to. Thanks
71 Lemans Sport. 72 Lemans Sport. RIP 75 Grandville Convertible. |
your going to have too it will just keep spinning on the wheel had to do it myself broke my heart to do it lol
Or buy some bead lock wheels.
I glued mine...
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads Faster on nitrous… |
High tack or my tire guy still swears by hairspray
Illinois Outlaw Gassers 6.27@107 9.97@131 |
You can always do what I did: buy used wheels that are already tapped for screws.
![]() Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
Are radial slicks an option? I run mine at 17-22 PSI, which counteracts slipping.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
What brand of wheel? Weld offers bead seat knurling, may help with your situation.
Not sure what tires we are talking about but just a fyi you can NOT screw radials
I use Permatex Aviation sealer. Stays put and does not move.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135 66 GTO (Retired race car) 421 CID Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
I just let them move, but I rotate them every race. They settle in to where they don't move that much. Just make sure the tires are tubeless.
I am running Hoosier radial slicks hoo 18211. I run them at 20 psi.
If you are just having a little movement, I would mark them and keep an eye on the actual amount and rotate as mentioned. I might also be inclined to try some of the chemical remedies before drilling the wheels. We ran screws in the Grocery Getter wheels and it's a PIA. The screws eventually work loose, they eventually strip out in the wheel. They also lose a tiny amount of air around some of the screw holes. The wheels are hard to clean with tire/rubber dirt getting in and round all the screws. We had to eventually use 16 screws on each wheel face, 32 total because just 8 caused the tires to wrinkle so badly, they caused tire shake. The 16 screws did help this allot. We should have gone to double bead locks, a much better set-up but adds lots of rotating weight. I would tend to live with minor movement.
Mike is this what you used permatex 80019?
I've used Permatex Hi-tac brush on sealant (red stuff) and had great success with that on Bias slicks and MT street radials. Gone 1.32 60's that way on the bias.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
yes.
Brush a small amount on the bead of the tire. Any excess wipe off with brake cleaner while still fresh after assembled and aired up. I run the MT Pro Bracket Radial with 18-20 PSI and this has worked well.
I used dish soap when my radials were mounted, they moved a couple of inches and stopped moving now. 1.26 best 60 ft
On my steel steels, I just used black bead sealer. But I only 60 1.43
Mike Thanks for the info on the sealer. I got some yesterday from a friend.
