Old 04-21-2017, 06:32 PM
Carmine Carmine is offline
Default Automatic choke
Hi everyone. I just got my '71 Q-Jet returned from a rebuild. Looks good and appears to act fine except for the automatic choke. It doesn't close when I try to start the engine. The butterfly moves freely and will close if you hold it. Other then that, it stays open. I have a suspicion that something is missing. I posted 2 pics. Might not be the best, but does anyone see something that is missing from the choke mechanism. I could probably take a better side shot tomorrow. Thanks, Carmine.
Name:	Carb pic 1.jpg
Name:	Carb pic 2.jpg
Old 04-21-2017, 07:32 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
I don't see the Choke stat on the manifold. It is what makes the choke work.
http://assets.hemmings.com/story_ima...00-0.jpg?rev=1
Old 04-21-2017, 08:21 PM
Nope. Don't have it. Didn't know I needed it. Certainly explains it. Many thanks, Carmine.
Old 04-23-2017, 08:28 PM
sonjaab's Avatar
sonjaab sonjaab is offline
Need a good pic of the right side of the carb and intake.
Is there a well in the manifold on the right side?
If so then a choke (stove) thermo spring is mounted there and a cover is over it.
A rod will then run up to the choke butterfly to open and close it.
(according to temperature)
That is how my 72s choke operates.
BUT pretty sure this a 72 only deal so Im not sure about your 71.
The choke stove spring looks like this:
72 Lemans Sport convt., 84 Z-28, 13 Chevy Impala,
94 Buick, 77 Triumph Bonneville
Old 04-23-2017, 09:39 PM
West Coast GTO's Avatar
West Coast GTO West Coast GTO is offline
Carmine:
If you look at page #205 in the Ames catalog, you can see a 68-70 choke thermostat housing , coil and rod for $38. Says it will also fit a 71 455-HO but says nothing about a 71 400 CID.
Is there any detail / drawing in your assembly manual?
Old 04-24-2017, 06:29 AM
Originally Posted by West Coast GTO View Post
Carmine:
Saw that myself. Thanks. I was wondering if I could make that work somehow or what the difference might be. I will check the assembly and repair manuals. Good idea, Carmine.
Old 04-24-2017, 09:57 AM
ponchjoe's Avatar
Carmine, contact Cliff R or Shaker455 on the forum, they may be able to help.
