Old 05-01-2017, 11:29 PM
Default Starter wire harness retainer
Does anyone know if the wire harness retainer shown in the attached picture is in the correct position. This is a picture of my last Formula, and I have always installed this retainer in the front motor mount bolt hole, but I just bought a new retainer to replace the one on my 71 t/a that was missing, and the instructions show it as being at the rear of the motor mount.
Old 05-01-2017, 11:43 PM
Formulabruce's Avatar
My '72 And '73 had it in the front. I doubt they were messed with before I got there.
" Long may we DRIVE !"
Old 05-02-2017, 10:30 AM
TA455HO's Avatar
TA455HO TA455HO is offline
1971 Assembly Manual - Electrical Section - 484158 Sheet 1 of 7 has the detail of those clips. For LS5 one was used on front and one on back bolt of left hand motor mount insulator.
Chad
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
Old 05-02-2017, 11:21 AM
Judge273's Avatar
Judge273 Judge273 is offline
Need a picture...
Mike/Illinois
Old 05-02-2017, 12:40 PM
TA455HO's Avatar
Notice how this is "LS5 ONLY".
One clip is pointed to as number 20 in the parts listing. That is the rear clip and looks like Chris's (where did you get that one Chris?).
Then look for the "EXISTING BOLT & WASHER" text and follow the two lines from it and you should be able to make out the front and rear one. Here are the individual part numbers. Somewhere on here someone had a broken motor mount but it still had the clips intact and it was a decent picture of some real ones. Front one had a definite distinctly different shape to it, thus the reason for two part numbers.
20 478655 2.343 All A & F/455 H.O. CLIP, cable to eng. mtg.-rear 1 1971 1972 2-23
21 481216 2.343 All A & F/455 H.O. CLIP, cable to eng. mtg.-front 1 1971 1972 2-23
Old 05-02-2017, 01:15 PM
TA455HO's Avatar
See the second post down on this page and the picture that Giles posted - that's one picture anyway.
http://forums.maxperformanceinc.com/...6&postcount=22
Thing to note about these clips is they have a ridge bent into them to give them some rigidity. Not just a flat piece of metal. You can see the ridge in the Giles picture in the front clip.
Sort of like these - but these are for another application - just showing the ridge in the metal.
Chad
Old 05-02-2017, 01:36 PM
TA455HO's Avatar
Here's a link to the thread I was thinking about that Chuck posted. A few good pictures here. I wonder if Chuck still has them if he could take some good close up shots of just the clips?
http://forums.maxperformanceinc.com/...d.php?t=602121
Chad
Old 05-02-2017, 02:04 PM
Norwood's Avatar
Norwood Norwood is offline
Pictures
ID:	453648   Click image for larger version
Old 05-02-2017, 04:47 PM
Craig,
Did you ever repop those?
Originally Posted by Norwood View Post
Pictures
Old 05-03-2017, 09:36 PM
Norwood's Avatar
Never did but I'm pretty sure someone did.
Old 05-04-2017, 08:34 AM
blue71ta's Avatar
blue71ta blue71ta is offline
Inline Tube makes the one on the left; not sure about the longer one:
http://www.ebay.com/itm/190849274575...%3AMEBIDX%3AIT
Old 05-04-2017, 10:06 AM
TA455HO's Avatar
I have to disagree. While it has some similarities that one doesn't have the bend in the middle of it and if you took one of those and just tried to bend it more to shape I believe the ridge in the middle would cause it to buckle oddly if simply bent.
I also think the originals don't have the offset tab for the bolt hole, but someone with an original set (Weranc55, 68BirdHO) can maybe post a better picture of these clips?
Chad
Old 05-04-2017, 10:12 AM
TA455HO's Avatar
If you take a look at the post #8 by Norwood and look real close at the first picture - left hand side - I think you will agree that if the clip had an offset that it would not be hanging straight down from the bolt head.
Chad
Old 05-04-2017, 05:05 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
The clip Inline Tube repops is the later style. Started on the D-port cars in '72.
Old 05-04-2017, 05:18 PM
Norwood's Avatar
Here is the first one, I can't find the second one right now
ID:	453797   Click image for larger version
Old 05-04-2017, 09:58 PM
Held for Ransom's Avatar
Here is what the '70 used.
Old 05-04-2017, 10:01 PM
It only allowed one picture to post. But now the rest...
ID:	453846   Click image for larger version
ID:	453849   Click image for larger version
