Old 05-02-2017, 04:58 PM
lrosen's Avatar
lrosen lrosen is offline
Default tightening brake pedal rod lock nut under dash
A '67Bird:
Anyone know what magic tool or trick to use to tighten the lock nut on the MC shaft? There's not much room to get even a small wrench to do a full turn inside the pedal support. The nut flats are in a spot I can no longer get a wrench to line up for more turning (wrench offset in either direction). Every month or so I must tighten finger tight to remove play.
1967 Firebird 326 H.O. Conv., M3 floor shift, 3.36:1, Montreaux Blue/Parchment, Dual factory traction bars
2005 IBM GTO M6 - One of 347
1984 Yamaha FJ1100
Old 05-02-2017, 08:38 PM
I think this may work. You could get a quality box end wrench that was thin and cut a groove big enough to go over the shaft.http://www.ebay.com/itm/NICE-SNAP-ON...-/401302505090
Bill Nye.
