Old 05-16-2017, 03:38 PM
CanAmT/AGTO CanAmT/AGTO is offline
Default 71 License Plate Lamp Question
The wiring diagram in the 71 manual shows a ground lead off of the housing and grounded to the metal trunk tail panel.
Is this grounding lead supposed to be permanently attached to the lamp housing or is it attached by way of a the screws that secure the lamp housing to the tail panel?
The lamp works once I attached a ground lead to the base of the housing but I wanted to try and replicate the correct method of grounding.
Thanks in advanced
Larry
I Bleed Arrowhead Red,
64 GTO 389 Tri Power 4spd Nocturne Blue Poly
70 GTO 400 4spd Palladium Silver
75 T/A 400 4spd Buccaneer Red
71 T/A 455 4spd Cameo White
01 T/A Bright Red 4L60E Ram Air WS6
02 TA Navy Blue Metallic 6 spd Ram Air WS6
Old 05-16-2017, 08:25 PM
NOT A TA NOT A TA is offline
It's a piece that screws on. https://lab-14.myshopify.com/product...nd-description
John Paige
Lab-14.com
Old 05-16-2017, 09:12 PM
NOT A TA, I appreciate the info. Thank You
I will order this up,
Old 05-17-2017, 12:00 AM
Formulabruce's Avatar
The originals didn't have that "hoop" in the top as these do, But they should function just fine. Glad its being made, for sure.
" Long may we DRIVE !"
Old 05-17-2017, 09:04 AM
I used this original in pic below removed from my 70 as a pattern and car had not been hit in rear or anything. Perhaps there were slightly different versions 70-73? Anyone have a pic of one that looks different?
John Paige
Lab-14.com
Old 05-17-2017, 10:02 AM
Norwood's Avatar
Norwood Norwood is offline
Old 05-17-2017, 11:58 AM
All the ones I have removed look like Craigs above ( Norwood) 70-73
Old 05-17-2017, 12:16 PM
Thanks guys! Be easier to make them like the one in Craig's pic. Certainly not a high demand item but I had requests on other forums so I added them to the things I make.
John Paige
Lab-14.com
Old 05-17-2017, 12:18 PM
Norwood's Avatar
I was going to do them. Cancel that one
Old 05-17-2017, 10:36 PM
Guys,
Thanks for the pics and additional info, very helpful.
Not A TA, glad you are manufacturing these and thanks for the quick shipping.
Larry
Old 05-18-2017, 12:13 AM
I made a few from stainless steel. Clear coated they stay nice, but its not original material
Old 05-18-2017, 06:05 AM
Judge273's Avatar
Judge273 Judge273 is offline
Not like they are easy to see..
Mike/Illinois
Old 05-21-2017, 10:32 AM
John Paige
Lab-14.com
Old 05-21-2017, 08:50 PM
Great Job! Looks stock to me !
Old 05-29-2017, 12:43 PM
Pepi's Avatar
Pepi Pepi is offline
Here is a shot of my '73's.
What are the proper screws supposed to look like for mounting the light? When I look up the P/N 9420372 it has a very large washer attached to the head.
Name:	Tail Panel Ground.jpg
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
