Old 06-17-2017, 08:20 PM
Keith Seymore's Avatar
Default Header recommendation
My GP is the "mother of all exhaust leaks": I've just discovered my third cracked RH exhaust manifold.
I'd like to try a short tubular steel header and see if I can get past this and on to something else.
Anyone have a recommendation or a favorite for an inexpensive header for light driving (not Super high performance) use?
Thanks in advance -
K
'63 LeMans Convertible
'63 Grand Prix
Old 06-17-2017, 09:59 PM
66_Catalina 66_Catalina is offline
I have the cheap summit racing 2nd gen F body headers on my '66. It's pretty snug around the passenger A arm and the steering box but fit.
Old 06-19-2017, 11:50 AM
Willshire's Avatar
Willshire Willshire is offline
Ram air restorations ceramic coated cast headers never leak. i mean ever. lol they use steel gaskets to seal and the mounts are super thick, because, well, they are cast iron. bahahahahahaha. Seriously though, they are fantastic. required a mini starter but otherwise great
It's hard to soar like an eagle, when you're surrounded by turkeys!
My wife says she'd llike my car a lot more if it wasn't mine.
64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam.
Old 06-19-2017, 04:44 PM
Stuart's Avatar
Stuart Stuart is offline
I wonder why your manifolds keep cracking? Seems unusual to me.
Old 06-19-2017, 04:47 PM
Willshire's Avatar
I missed the "inexpensive" comment. My bad. Summit headers have 3/8" flange I think. Is your exhaust really tight? Is there lots of movement for the motor to twist? I too am curious about the cracking manifolds
Old 06-19-2017, 05:03 PM
They're bolted on tight at the flange. Not a ton of room for the engine to twist around.
Old 06-19-2017, 05:07 PM
Willshire's Avatar
I have found in the past if the exhaust system isolators are too loose and bouncy it has an effect on the manifold. Just a thought.
Old 06-19-2017, 05:09 PM
http://forums.maxperformanceinc.com/...d.php?t=797164
Old 06-19-2017, 05:29 PM
My system is pretty light. Headers, cherry bomb header glass packs, turn downs. Won't be a lot of flex
