SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 07-07-2017, 04:09 PM
antique69lemans antique69lemans is offline
Default Spotts pushrod elongation tool
Guide bolts in place of 7/16" stud. Drill included to clearance head for 1.65 rockers. Spotts performance still have them on website, but not made in awhile.
$30 shipped in small flat rate box
Old 07-07-2017, 05:08 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I'll take it!
Skip Fix
Old 07-07-2017, 05:21 PM
Goatster69 Goatster69 is offline
Dang it! Darn you Skip! :-)
Old 07-07-2017, 05:47 PM
Must be a collectors item ! So I've got a pm from someone else that beat you both by 7 minutes....what's the protocol here ?
Old 07-07-2017, 05:50 PM
Tick em both off and sell it to me. Haha.
Unless otherwise noted I have always gone with the first "I'll take it" but others can chime in just in case I am way off.
Old 07-07-2017, 06:12 PM
Skip Fix's Avatar
Most folks go with first contact. So PM would get it.
I did a set free hand and did not grind enough so have a set of heads to do and get the clearance right.
Skip Fix
Old 07-07-2017, 06:24 PM
Thanks Skip, so rules don't specify, but pm was to make payment arrangements as per forum guidelines. I'd say he gets it first. Maybe he'll start an auction lol.
SOLD pending payment, if it falls through Skip is next in line.
Old 07-07-2017, 06:26 PM
oldblueponcho's Avatar
oldblueponcho oldblueponcho is offline
Dang! That's what I get for going out for lunch!I know it won't get all the way back to me, but can I get in line? LOL.
Some Fear, Because if you've never been afraid- just a little. You're obviously not going as fast as you could be.
Old 07-07-2017, 10:45 PM
gixxer711 gixxer711 is offline
Talking
Dang it++++ I hope Skip gets it, he's close by and maybe I could rent it.
Old 07-07-2017, 11:41 PM
t money t money is offline
Can you post a picture of this tool. Hear about for years but never seen it
Old 07-07-2017, 11:58 PM
694.1 694.1 is offline
This may be an item worth re producing.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 07-08-2017, 12:01 AM
Lee's Avatar
Lee Lee is offline
I just chucked a rat-tail file in my drill, EASY on the throttle, and made pretty quick work out of it. A light coat of primer on the pushrods in the concerned area, mock it up, turn the engine over a few times... kept power-filing & rechecking until the primer was unblemished.
Having a proper tool would take all the fun out of it!
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 07-08-2017, 09:25 AM
Skip Fix's Avatar
Lee I ground pretty easily with a die grinder ,just not enough about 3/4" down so something to get the right angle might help me. My problem was I thought I had ground enough so assembled heads on it and didn't want to burn a set of head gaskets and time to reclean the heads to grind more.
I do have a Isky piston notching tool I've let some of my 409 guys borrow to notch the block for the exhaust valve when using a big cam. Over .520ish the exhaust valve hits the combustion chamber built into the block. So passing it around wouldn't be an issue. Not sure if the drill wears it out after awhile. Comp makes one for old iron SBC heads.
Skip Fix
Old 07-12-2017, 11:27 PM
Mod. Please move to SOLD
