Old 07-25-2017, 11:42 AM
FirebirdHank's Avatar
Default rear main seal question
Can the rear main seal be changed to a one piece seal with out pulling the engine? The engine is in a '69 Firebird with a 350 & manual trans.
It seems to me that it probably can't but just wondering what others have done.
The transmission has to be removed to change the seals as well so we will be looking right at that rear main.
Old 07-25-2017, 11:45 AM
tom s tom s is offline
not a chance,the crank has to be removed enough to get it around it.Tom
Old 07-25-2017, 12:13 PM
steve25 steve25 is offline
You'LL not get the upper rope seal out without having the Crank out!
Old 07-25-2017, 12:27 PM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
I have done them in car
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
Old 07-25-2017, 12:32 PM
Richie,you have done the one PC BOP rear seal in a 69 bird?You are superman!Tom
Old 07-25-2017, 12:36 PM
Not much fun is it, in fact PIA barely does it, no?
Old 07-25-2017, 01:00 PM
FrankieT/A's Avatar
Even if you could...I wouldn't. You'll probably have a worse leak than you started with.
Old 07-25-2017, 01:09 PM
geeteeohguy's Avatar
Nope. You'll have to pull the engine. Not a bad job, and you'll be able to clean and reseal the whole thing while you're at it. Freeze plugs, paint touch up, etc. And a great opportunity to detail out the engine bay. Even with a 2 piece rear main, pulling the engine is the only real way to do an effective job. And in the end, its cleaner and actually less of a struggle.
Jeff
Old 07-25-2017, 01:12 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Richie is a RMS Ninja!
Go fast, see Elvis!
Old 07-25-2017, 01:26 PM
Schurkey Schurkey is offline
SO true.
Even if it "can" be done...it shouldn't be done in the car.
Yanking the engine drops the frustration level to about 1/10th, and triples the chances of a successful completion.
Old 07-25-2017, 02:06 PM
It can and has been done "in vehicle" for years(Kent-Moore makes a tool for this purpose) but I don't recommend it unless you have no other choice.
Dr. Thomas Sowell
Old 07-25-2017, 02:33 PM
Pontiac Performance Author
The problem with installing a neoprene seal "in car" is that you cant fill the "anti-rotation holes" in the block, and oil will bypass around the seal.
Old 07-25-2017, 02:37 PM
rohrt rohrt is offline
I call BS on anyone saying it can be done in a firebird. You can't get the pan off. At least I couldn't. This was with the motor jacked up as hight it could with the trans still attached. By the time you disconnect all that you need to, to raise the motor your about 45 minutes from pulling it any way.
proof
Old 07-25-2017, 05:14 PM
I have pulled the oil pan in first gen firebird with trans in car
2008KRE Q16 Winner
tube chassis car?Tom
Old 07-25-2017, 08:44 PM
Regular chassis street car
2008KRE Q16 Winner
