Old 08-22-2017, 09:23 PM
Dave M's Avatar
Dave M Dave M is offline
Default Looking for PTFB solid bushing tips
While the engine and trans are out of my 68 Convertible, I thought it would be a great time to install solid body bushings. Also, based on the advice from my subframe connector post, I thought I'd better do it. We're trying to replace 1 at a time, and it's not going well. So far, we only got the rear drivers side in. We can't seem to jack the body high enough off the subframe. Any advice would be appreciated.
Old 08-22-2017, 09:36 PM
Dave M's Avatar
I also have these bushings from CE
https://m.summitracing.com/parts/cee-3027
But those need part of the stock bushings to work. My stock bushings are pretty trashed though
Old 08-23-2017, 09:04 PM
Dave M's Avatar
My son, we'll call him Jacob, was able to get the 4 important ones in. We used the PTFB mounts. Will maybe replace the core support mounts with stock mounts some day.
Old 08-23-2017, 09:29 PM
Toms bird Toms bird is offline
I just put in solid bushings. I didn't really have a hard time. I think I remember loosening one side completely except the front radiator core support one and using a piece of wood to pry enough to slip them in.
Old 08-23-2017, 10:51 PM
Dave M's Avatar
Might have been easier if we had a lift. Or if the car was apart.
Sent from my iPad using Tapatalk
Old 08-31-2017, 12:11 AM
Donovan Donovan is offline
loosen opposite side half threads.... take the side you are working on completely loose. Jack up on body with a board to spread the load. Not bad at all.
Put new side together half threaded and loosen the other side completely. Repeat.
What Tom said.
Old 09-01-2017, 11:02 PM
amcmike's Avatar
amcmike amcmike is offline
That's basically how I did it, except I think I loosened the core support one as well.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
