I am trying to put my engine combo together and one variable is exhaust. Are the reproduced ram air manifolds from pypes round port or d port? Does anyone know of an exhaust shop anywhere between Atlanta and Charlotte that can mandrel bend exhaust?
Have you checked with the Pipes system?Tom
"...Are the reproduced ram air manifolds from pypes round port or d port?..."
D-port. https://www.summitracing.com/parts/p...caAiXhEALw_wcB R.A.R.E makes the big outlet round port manifolds. http://www.ramairrestoration.com/rm-...oversized.html |
Ponyakr touched on it. You can get the big outlet D ports and round ports as well as stock outlet D port and round port. Some of these I've seen somewhere even offer a porting or "clean up" service. Might have been R.A.R.E.
No reason for a shop to mandrel bend pipes in-house. The good shops in our area carry a large quantity of mandrel bent tubing pieces in all the necessary angles, and then simply cut and paste a custom system together.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Exotic Exhaust
7 Ritch Drive Hiram, GA 770-943-2153 .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
Yes I do that here occasionally when I have an unusual swap where mandrel down pipes aren't made. The mandrel "J" bends aren't expensive to buy, then just cut-turn-angle-weld how needed.
