Old 09-29-2017, 08:13 AM
gman005's Avatar
gman005 gman005 is offline
Default Dominator HP Problems.
I put on my Dominator HP and filled the bowls and it looks like its leaking fuel from the primary throttle blade shaft. WTF. This carb has hardly any time on it.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport. RIP
75 Grandville Convertible.
Old 09-29-2017, 08:15 AM
PAUL K's Avatar
PAUL K PAUL K is online now
Sounds like the primary N&S assembly is not sealing. Is there fuel dripping out the boosters?
Go fast, see Elvis!
Old 09-29-2017, 08:25 AM
gman005's Avatar
I Didn't see any. I did not hit the throttle to prime it.
71 Lemans Sport.
Old 09-29-2017, 08:30 AM
gman005's Avatar
I'm not sure what N&S is Paul?
71 Lemans Sport.
Old 09-29-2017, 09:00 AM
73 TRANSAM 73 TRANSAM is offline
John, Needle and seat N&S is where you adjust the height of the float bowl. When its not sealing it usually puts fuel on the vent tubes.
Old 09-29-2017, 09:07 AM
gman005's Avatar
I knew that I'm still sleeping. LOL
71 Lemans Sport.
Old 09-29-2017, 09:27 AM
grandville455's Avatar
grandville455 grandville455 is offline
-008 O-rings, back up n running
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 09-29-2017, 09:32 AM
gman005's Avatar
Just checked it again both bowls are full of fuel. I wrapped a rag around both fuel lines and turn the pump on. It is definitely coming from the throttle shaft.
71 Lemans Sport.
Old 09-29-2017, 09:33 AM
gman005's Avatar
That's the size of the oring for the throttle shaft Darby?
71 Lemans Sport.
Old 09-29-2017, 09:43 AM
Sorry John, No for the needle,, Not sure how your getting fuel around the throttle shafts?
Darby
Old 09-29-2017, 10:42 AM
gman005's Avatar
Ok Thanks. I like the new picture.
71 Lemans Sport.
Old 09-29-2017, 11:20 AM
steve25 steve25 is online now
Pull out one of the lower fuel bowl screws to drain it out, catch that fuel then pull out the sight plug and pour that fuel carefully back into the fuel bowl vent until it's fills up that bowl until just below the sight plug, do you still see fuel coming out the throttle shaft?
By the way fuel seen coming out the shaft ends is coming from some where else.
Thanks John! That was sunday at TNT before Drag week. I dunno y u are getting gas around the throttle plates, Did u fill the bowls and look down inside the venturis? Sure its not coming out of the boosters?
Darby
Old 09-29-2017, 12:24 PM
gman005's Avatar
Nothing coming out of the boosters. -008 O rings are 3/16 id and 5/16 od?
71 Lemans Sport.
Old 09-29-2017, 03:50 PM
gman005's Avatar
It's fixed. The floats were to high. Thanks again for the help Edwin.
71 Lemans Sport.
Old 09-29-2017, 05:42 PM
Tom Vaught's Avatar
Boost Engineer
Once in a while you see an issue with the float level because the carb is on a funny angle due to engine installation. Dominator carbs have both sight plug holes in exactly the same spot
height wise whereas the older 3310 type carbs would have one sight hole higher vs the other one due to the engine angle and carb pad angle.
But the fix many times is just set the fuel level in the bowl so that when you bump the car with your hip the fuel slosh just barely dribbles out the float bowl hole.
Many set the fuel level higher in error.
Tom v.
Old 09-29-2017, 05:54 PM
Old Goat Racer's Avatar
That "bump trick" is prolly older than I am. Question is how did the floats get out of adjustment ?
Everybody knows somthin.
Nobody knows everything !
Old 09-30-2017, 09:24 AM
Tom Vaught's Avatar
Boost Engineer
I have been using that trick since the early 60s on Holleys, to check fuel level.
Had a SB Chebby before my 64 GTO.
Many times the dry setting I do (by eye) with the bowl turned upside down is spot on the money.
No paper measurement strips like a Rochester 2 BBL deal required.
Don't even do the bump test many times anymore.
Tom V.
Old 09-30-2017, 08:01 PM
gman005's Avatar
That's a good question Ron.
71 Lemans Sport.
Old 09-30-2017, 08:25 PM
PAUL K's Avatar
Pull the bowls off and check the floats. Make sure they're not fuel soaked, cracked or collapsed. Look for contamination inside the bowls.
Go fast, see Elvis!
