I'm ready to hop off the fence on my build and buy a crank. Who has the best price and quality on a Scat or similar forged 3" main, 4" stroke crank for a 400 block?
The Spotts' site shows forged cranks for $649 + shipping. If that price is current, it's the best I know of. Have no idea if price is current or if he has one in stock.
http://www.spottsperformance.com/cranks.htm RPM shows one for $720. http://www.racingpartsmaximum.com/fo...sae4340-4.html KRE shows 'em for $750 + shipping. You may have to call around to find one in stock. http://www.krepower.com/Pontiac%20Cr...and%20Rods.htm Sandoval's price is $795 + shipping. http://www.sandovalperformance.com/_...2-stroke-crank The Butler price is $800 + shipping. http://butlerperformance.com/i-24453...tegory:1234870 Last edited by ponyakr; 10-08-2017 at 02:25 AM. |
These were on back order several months ago. I ordered one from Paul Knippen's Muscle Motors and ended up with two cranks as our prior order came in. I think Paul kept the second one that came in so you might want to drop Paul a line at (630) 400-4441 as he may still have it in stock. If not, he can get you one at a fair price.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
Are these a 2.20 crank pin?
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
Yes, these use the BBC RJ.
KRE is out of the standard weight scat forging. I sent Paul a PM on FB asking what he had in stock. What do you guys think of the RPM forgings?
I would definitely have it magnafluxed and stroke/journals checked before using it. I've heard good and bad about their forgings. Also, have the hardness confirmed. If the crank grinder you take it to has no idea what I'm talking about, RUN! PM me and I send you the phone number of crank grinder who does.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
The dimensions on my Scat forging were near flawless.
Aren’t most of the overseas pieces forged at the same places?
Has anyone ran the cast 4" stroke cranks hard and had trouble ? Bet with that short of stroke they are pretty tough. The cast 400 cranks hold up very well.
China is such a big market for vehicles and industry there are MANY MANY Forging houses for steel products. One of the largest Turbo manufacturers has a new massive Plant in China and is using China Aluminum, China Steel, and China Workers to put the stuff together. So to assume that a few places are making all of the parts might be a stretch. There are 'layers" of manufacturing: Jim/Bob's Forging House, ABC Forging House, General Motors Forging House, etc. GM sells more vehicles in China than the USA/ Mexico and possibly Canada sales combined in a year. A Lot of Buicks. SCAT has a high enough volume that they can use a quality Forging House. And possibly they still do all of the machining of their cranks still in the USA. Being "spot on" with a SCAT crank does not surprise me. Tom V.
If one asks a crank company where the steel is sourced from, most...if not all will tell you it is proprietary info. I was told this from Ohio Cranks when I purchased my billet crank. Doesn't hurt to do your homework. Ask around and see if you can gleen any info on the base steel and it's origins. I'd think if any crank manufacturers are using "High Grade" American steel...they'd display it and wear it like a crown. One can source "dirty steel" from any country....including the USA.
You say SCAT uses a quality forging house. I gather SCAT has the ability to Xray, if you will or do whatever else is needed to determine if the forgings are up to their standards? Again I'm asking as I know very little about this. Is SCAT the only one doing this? I have a SCAT 4.25 forging from Butler's and a Star Galaxy 4.500 forging from FrankG. I don't really care which one I use, but I prefer the better of the 2.
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- Last edited by Jack Ferris; 10-12-2017 at 10:51 AM. |
Have no knowledge of the Star Galaxy Cranks. believe Butler and Frank were involved in some deal with them.
The Scat stuff first sold by Wade/Mark (BOP) and Bob/Frank were good cranks for the money. Metal was pretty clean. Clean metal means less chance of a imperfection causing a crank in the crank and it failing. Have no knowledge on the new Scat Cranks, only the fist run stuff which I bought 3 of them. Tom V. To
Molnar uses his own source of Chinese steel. Scat likely has their own source. StarGalaxy Cranks initially tested good.
I decided that a fully counterweighted billit of high quality us steel is worth it.
My star galaxy had to be replaced after one season. Lots of cracks.
Wonder if one could source an unmachined forged 3" main 4" stroke in a shipment of SCAT's???
Would like to duplicate a 4.06 stroke crank, but with 3" main, need 2.25 rod journals in order to offset grind.
Be worth a call OPH!
Tom V.
My 4.250 Star Galaxy I bought from Butler in 07 is still perfect. And it see some decent power in a heavy car.
Yours would be a piece of cake, not that expensive either. |
