Prev Previous Post   Next Post Next
Old 10-17-2017, 04:31 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Default th350 filler tube o-ring seal
I need to replace the filler tube o-ring on the th350 in the Bird. Is the fluid level below that point in the case or will I loose fluid out the filler tube hole? Thanks.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far...
