I'm looking for good quality side mirrors. The ones I currently have will not stay they're just floppy as hell. and suggestions?
6.98 @ 199mph 4.53 @ 164mph |
Is there no way to get the glass out and tighten up the swivel ?
I have the same problem. All the reproduction side and rearview mirrors have the problem. If possible, try a small dab of blue loctite in the swivel. Otherwise, you will just have to rebuy them over and over.
On the OEM mirrors I though it was possible to remove the mirror glass and there was an adjustable tension mechanism inside.
On the old bullet aftermarket mirrors there was often a screw in the end of the cone, attached to a tension spring, you'd tighten that screw to adjust it. Seems like I've also seen them with a tension screw in the base, that you can see without removing the mirror. Might also be able to move the mirror far out of place, take a center punch and dimple the ball a little bit ... but eventually that would probably wear out. On that car you might need to weld them in place
Cool picture....
First I read the thread title, Then looked at the picture & thought "well, there's your problem"
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
I guess i'll try and epoxy / glue them some how.
Or just slow down.
JK, I realize they shouldn't move that easily, just funny when you look at the force thats going on in the picture.
LOL I know. At 194mph they all are hone move but these junkers wont even stay put in the garage.
I've been trying to figure this out for years along with many others, huge pain in the a$$.
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR 236/242D .572/.594L, RA manifolds, 11.53@114, 1.55/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, Howard HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
If they absolutely have to stay in the same place all the time ... yeah, epoxy or a bit of silicon bronze weld. Or maybe they can be drilled through with a small bit and pinned with a split pin.
PERFECT! Thank you
I use red loctitie. fwiw
Don Hayden <[email protected]> 68 GTO, 70 Tempest Wagon, Two GMC's, a caddy & the FULMNTE |
My two solutions; change to a remote mirror,
or take the regular mirror off the car, place it face down and carefully hammer a spike at 120 degree intervals where the swiveling part meets the ball. Does the trick!
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & a 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 2 Bonnie Cvt's & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
Shoot it with a small caliber rifle and it will be harder to move.
