Old 03-08-2018, 09:16 PM
dbiggs dbiggs is offline
Default Vinyl top molding
Can anyone help me out with how many spring clips are used for the molding? Got a kit from Ames which has 6 rail clips and 6 spring clips. I have 8 spring clip holes on each side. Not much help when I asked tech at Ames. And do the v shaped moldings only use the spring clips?
Resto almost done - 1966 GTO HDTP Tiger Gold (paint code 1-2), black vinyl top and interior, 389 tripower, 068 cam, TH-350/Hughes TC, RA manifolds, 2.5" Pypes exhaust, Scarebird Front Disc, Ralley II's, factory PS, PB, PW, PA, A/C, headrest option.
Old 03-09-2018, 04:01 AM
Old Goat 67's Avatar
Four clips each side. Two screws front one, one each next three so those can pivot.
Three spring clips for each V moulding, one outboard, two inboard. You can see the 1/4" holes if you look closely at the two pictures.
ID:	477660   Click image for larger version
Old 03-09-2018, 11:49 AM
Hey thanks for you help...so looks like no spring clips for straight molding based on you pic? I have those 1/4" holes down the sides as well as for the v shaped molding.
Old 03-09-2018, 11:51 AM
Another pic
Old 03-09-2018, 11:52 AM
I don't have the small holes for the screws...not sure if body man filled them in. Does your car have the 1/4" holes along the side?
Old 03-10-2018, 06:31 AM
No sir, just the small screw holes. Mine was a KC car, where was yours built?
Those may have been drilled out to be able to use the spring clips instead of the snap on clips??
Old 03-10-2018, 11:26 AM
Mine is a CA car. It sure looks like these are original holes, been so lone since I tore down car I don't remember how they were attached. Tried to get Ames to sell me more spring clips separate but I have to buy another kit. Have to find the remaining clips elsewhere.
Old 03-10-2018, 12:12 PM
gtospieg gtospieg is offline
FWIW...my 67 is also a Ca. car and it did not have the metal "clips" shown in Old Goat 67's photos. I assume the clips I used are the spring clips you are referring to. I don't remember how many there were but I did have to get more than came with the kit from Ames.
Old 03-11-2018, 07:20 PM
Thanks to both of you for your input...you solved my dilemma...going to order more of the spring clips and go with it.. 👍
