Old 03-24-2018, 06:07 PM
cjatx's Avatar
cjatx cjatx is offline
Default Copper or Graphite Exhaust Gaskets
I'm struggling with exhaust leaks at the center ports on both sides of the engine. When I install new gaskets, it helps significantly, but eventually they burn up at the centers. I have stock manifolds and thought I would try a higher quality gasket before taking the the manifolds off and having them machined. I'm considering copper and/or graphite. Any recommendations?
Thanks,
Chris - 70 TA Ram Air III 4 Speed
Old 03-24-2018, 06:31 PM
tom s tom s is offline
Have had no failures with the Remflex.Tom
Old 03-24-2018, 06:46 PM
JSPONT's Avatar
JSPONT JSPONT is offline
x2^^^ if the manifold is not perfect these cure that.
Old 03-24-2018, 08:02 PM
cjatx's Avatar
Thanks guys. I'll give the Remflex a try.
Old 03-25-2018, 11:19 AM
Formulajones's Avatar
I use copper on everything, headers and manifolds. Never a problem, reusable, and last a lifetime.
