Old 03-25-2018, 06:17 AM
aasmilyy aasmilyy is offline
Default Best wiring kit for firebird 1974
Hi,
I have som issues with my electrical and looking for the best "kit" replacment for a Firebird 1974. Complete kit for the whole car or just the enginge harness,
what do you suggest?
Firebird 1974
Engine 428 (440 cui)
Kauffman D-port 310cfm
Roller Cam
Dougs 1 3/4 headers
portmatch Qj intake
800 cfm QJ
3000 rpm turbine
3,73 Rear
Th400
Caltracs
Old 03-25-2018, 07:05 AM
77 Canamman's Avatar
The correct and best answer is our board sponsor AMES.
However, here is a link to a PDF file for M&H Electric Fabricators which produces several harnesses and battery cables for 1974 F bodies..
http://www.wiringharness.com/PDFS/FIR_2016_Firebird.pdf
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 03-25-2018, 02:06 PM
TAKerry TAKerry is offline
I would second Ames, only because I have been happy with every purchase from them. That said, I am the farthest thing away from an electric guy, but why do you want to replace everything? It may be easier and cheaper, to start tracing things down. Most electric problems can be solved easily with fixing a bad ground. When I did the resto on my 77 all new harness' were on my list. However once I got the car running and started to pull the bad crap out of the way, making sure I had good connections and the grounds were good, everything worked as it should. Wires generally don't go bad just because.
Old 03-25-2018, 07:21 PM
critter's Avatar
critter critter is offline
You can't go wrong with M&H. Used them on my 74 TA.
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
Old 03-25-2018, 07:50 PM
jhnichols2 jhnichols2 is offline
I second what TAKerry said. I used to be intimidated by electrical wiring, but it is not that difficult to check. I have restored / refurbished dozens of wiring harnesses for late 60's to mid 70's cars. If the harness is out of the car , it is easy to check continuity using an ohm meter. I have a large container full of old wiring and lots of original connectors. You can easily purchase the correct style spade pins other ends too.The correct looking wrap is also readily available. Just yesterday I made the correct wiring for my 1967 GTO under hood light.
Also, if you post more specifics about your electrical issues there is a wealth of knowledge amongst the members here.
Old 03-26-2018, 11:16 AM
Speargun's Avatar
Speargun Speargun is offline
I can't speak for any other brands, but I used American Autowire in my '67 bird and am very happy with it. It came with everything needed, including ALL of the factory type (Packard 56) connectors, and the wires were extra long to re-route different than the factory locations.
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
Old 03-26-2018, 11:53 AM
Lee's Avatar
Lee Lee is offline
I've not bought a wiring harness from any of them, to be upfront on this topic. But, at one time at least, M & H was supposedly willing to customize their harnesses to match the modifications to your car. Things such has switching from external to internal regulator alternator, points to HEI, a power lead for electric choke, extra "switched" power sources under the hood, etc.
Maybe all of them will offer such things now, or maybe none of them. But with a modified car, it might be something to inquire about.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 03-27-2018, 06:47 AM
Aus78Formula Aus78Formula is offline
Any are a compromise. You won't get all the options for all vehicles and you won't always get matching plugs to original. They don't simply swap into place where the original once was, and you often have to modify anyway. It's easy to get a decent used complete harness, or 5, and can then adapt and modify to suit, replacing where it needs it or simply reusing plug where they are unusual with new wiring. It depends what you need and how much you are prepared to do yourself.
Old 03-27-2018, 02:45 PM
It is my fusebox that there is some rust in and the engineharness is bad too, but maby i am going to look on ebay if there is something that i could use
thanks for all your replys
Firebird 1974
Roller Cam
Dougs 1 3/4 headers
portmatch Qj intake
800 cfm QJ
3000 rpm turbine
3,73 Rear
Th400
Caltracs
Old 03-28-2018, 08:34 AM
I would not mess with a 45 year old harness. The insulation breaks down. A high quality fresh harness is always better in the long run. It's not worth the reliability or fire risk...
Old 03-28-2018, 11:20 AM
unruhjonny's Avatar
Originally Posted by Aus78Formula View Post
Any are a compromise. You won't get all the options for all vehicles and you won't always get matching plugs to original. ...
umm, I'm not sure where you're getting your information, but I think you might be wrong on this.
The looms sold through Ames are direct replacements, with same coloured wires and plug ends;
and you order it based on your car's configuration.
1970 Formula 400
Old 03-30-2018, 04:21 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
Lectric Limited is who I used. They make the harnesses in house and can customize based on what you tell them your car has in the way of changes since new, etc. They also have a lot of the important changeovers for mid-year and model year changes with notes on the website to help get the right harness. Mine were a perfect fit and took less than 10 days to get them after ordering.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 03-30-2018, 05:46 PM
poncho4554spd poncho4554spd is offline
I have seen a MH harness on a 72 and it seems to be a nice quality. It has the correct color wires and plugs
Old 04-02-2018, 04:12 AM
do anyone know where i can find a "fuse box terminal repair kit" that fit in the firebird fusebox? if i can find new terminals i can restore the rosty one in the fusebox and then just buy new engine harness
Firebird 1974
Roller Cam
Dougs 1 3/4 headers
portmatch Qj intake
800 cfm QJ
3000 rpm turbine
3,73 Rear
Th400
Caltracs
Old 04-02-2018, 09:43 AM
Contact Delmar Wire and Products. 909-947-1407
You will need to buy 25 or more terminals, but they should be able to help you out.
