Old 04-20-2018, 02:56 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Default center console light & glove box light assy
Are these two lights the same part? My console never had a light, but has the provisions. I am not seeing a separate part for the center console light.
Thanks!
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 04-20-2018, 04:16 PM
gto4evr gto4evr is offline
yes they are. but you have to add a ground wire to that tab off the side and ground it to the screw below going into the floor pan. Just make sure you have a 68 console insert with the matching hole too or nothing will bleed through. AND make sure it's really going off when the lid's closed, they can be touchy. If it's not going off consistently, put an o- ring around the fingers at the base so it doesn't push in so far. The lid contact isn't very tight and if the spring is missing it can pop up.
Old 04-20-2018, 04:48 PM
If I'm not mistaken only automatic consoles had a light, probably because they could easily connect to the shift indicator light as a power source.
Old 04-20-2018, 04:55 PM
North,
nope, I've got a 68 4 speed console with it. I don't think they'd use the shift light anyways since you'd have to have the lights on for it to work. It had a long orange power wire running up to the accessory junction block.
Old 04-20-2018, 05:08 PM
I think you are right about 68, in 69+ they discontinued it. The 69 shop manual shows it but the drawing is of a 68 dashboard.
Old 04-20-2018, 08:21 PM
yeah, it was 68 thing only. I've had quite a few 68-72 consoles over the years when I'd buy every one I saw at the swap meets for $10. (those days are gone!) I'm guessing they deleted it due to problems with it staying on and that the light it throws is so crappy there's no real point since it doesn't help see what's below the hole anyways. There's a TSB in one of the years about the problem in the glovebox light being remedied with the o-ring. The switch on my console barely disengages when the lids closed so the same trick fixes it there too.
Old 04-21-2018, 12:31 PM
Verdoro 68's Avatar
Funny, I always assumed it was on the manual consoles since my automatic ‘68 doesn’t have a console light. Maybe they dropped it mid-year?
Ken
'74 Ventura 350
'69 AMC Javelin SST
