Old 05-06-2018, 07:52 AM
67428HO 67428HO is offline
Default Hideaways colors?
Hi , what shade of black for the hideaway doors , brackets and linkage? Thanks
67428HO
Old 05-06-2018, 11:35 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
What year?
Backside brackets, etc would be 60% gloss. on the 68's the grills are argent silver (like the rally II wheels. black in-between & backside of the fins of the grill are closer to the sheen of bare plastic. 30% give or take. semi flat I would say. I have lots of pictures of my 68's finished & I matched an untouched original.
69's I am unsure on the grills, but the brackets would be the same as 68
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 05-06-2018, 11:57 AM
68"s Also what's the difference in the buckets, between a hideaway and non hideaway? Ames catalog says headlight trim rings will not fit right side with hideaways. why? Thanks.
67428HO
Old 05-06-2018, 04:04 PM
68ragtop's Avatar
buckets & rings are the same between hide-aways & std, but left & right side are different on the rings, & the buckets get even screwier. Hi/Low & left/right specific as I recall.
89 Trans am GTA
Old 05-06-2018, 08:51 PM
kk68's Avatar
kk68 kk68 is offline
Here are picks of my hideaway headlight assemblies after restored. Trim rings all appear to be the same. Buckets for R and L are different because of the spring location. Top tab of the buckets are stamped with K (outer) and J on (inner) on Right assembly; A (inner) and B (outer) on Left.
I used semi-flat, closer to 30% gloss when I painted these years ago. 60% gloss may be more correct. Hope this helps.
ID:	482436   Click image for larger version
ID:	482437   Click image for larger version
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
Old 05-06-2018, 08:57 PM
Thanks for the info!
67428HO
Old 05-08-2018, 06:47 AM
68ragtop's Avatar
Mine looked kinda semi flat. I know they were dipped in paint like so many other parts in our cars. Under the grills, mine had some nicely preserved paint that was about 60%, so I restored them that way. But the 30% probably looks closer to what they all looked back in the day when they were just a few years old. No doubt thats a good look.
89 Trans am GTA
