Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 06-23-2018, 08:08 AM
Hillard's Avatar
Hillard Hillard is offline
Default Wanted - Hyd Roller Cam
Looking to see if anyone has a hydraulic roller cam they are not using. Something in the 230 - 240 @ .050 range and .500 to .550 lift.
I'm doing something I wouldn't normally do, but I'm throwing together a motor full of junk and mismatched parts I have laying around. Cam and carb are the only things I don't have so I'm not being picky. Whatcha got?
Old 06-23-2018, 03:59 PM
Hillard's Avatar
On second thought, I'd consider a flat tappet (hyd or solid) also.
Old 06-24-2018, 12:22 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
I have a healthy hydraulic flat tappet cam (used but in good condition) and a brand new set of the good comp lifters (with the oil hole in the lifter face). I think it’s around 260 duration @.050 though. If you’re interested I can get more info.
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 06-24-2018, 07:27 AM
Hillard's Avatar
Thanks, but I'm guessing with that much duration it has a good amount of lift also which probably won't give me enough piston to valve clearance with the stock pistons. I appreciate the offer though.
Old 06-24-2018, 11:34 AM
69FIREBIRD76MM's Avatar
I got used hyd. Flat comp cams 51-316-4 , with comp magnum lifters, few street miles and few quater mile passes, was in my 455 trw's, #62's heads no PTV.
Old 06-24-2018, 12:30 PM
Hillard's Avatar
pm sent
Old 06-24-2018, 02:55 PM
Default camshaft
Pm replied.
Old 06-25-2018, 05:18 AM
Hillard's Avatar
Still looking.
Old 06-26-2018, 10:11 PM
Hillard's Avatar
Going to use a cam my dad found. Thanks for all the responses.
