Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 08-03-2018, 07:45 AM
ebgto ebgto is offline
Default Comp Cam Roller, barely used @ Norwalk
This roller cam was used on startup and about 100 miles in a new 535 in a car I bought. Needed to switch cams to lower dynamic compression. See specs on Cam Card. Will be at Norwalk. Pm me your phone number if you are there. $225.
'67 GTO Convertible - a couple extra HP, On the road!
'68 GTO Convertible - in frame off stage
'67 GTO Hdtp, HO 4 speed - next
Old 08-03-2018, 07:46 AM
Let’s see if this is right side up.
Old 08-03-2018, 09:07 AM
61-63 61-63 is offline
You've got a PM.
Old 08-03-2018, 10:55 AM
gs462's Avatar
gs462 gs462 is offline
Hydraulic roller??
Old 08-04-2018, 01:25 PM
Sold. 61-63 was the first to PM me and he took it. Thanks for the interest.
Old 08-04-2018, 06:21 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Is that the butcher special?
Old 08-04-2018, 06:31 PM
If you would look at the specs on SD Performance's "Stump Puller" cam this one is basically the same cam but with .007/.006 less lift at the valve.
http://www.sdperformance.com/listPro...p?categoryID=2
Old 08-12-2018, 04:06 PM
nmoreilly nmoreilly is offline
[QUOTE=61-63;5914546]If you would look at the specs on SD Performance's "Stump Puller" cam this one is basically the same cam but with .007/.006 less lift at the valve.
http://www.sdperformance.com/listPro...p?categoryID=2[/QUOTE
John - is that god no to go into the motor you out into your Catalina ?
Old 08-13-2018, 08:05 AM
No I got this for my son's GTO engine. The cam going into the '63 motor is a much more radical 241/[email protected] cam on a 108lsa.
