Old 08-25-2018, 12:24 PM
racerboy's Avatar
racerboy racerboy is offline
Default Choke pull-off vacuum
Hi everyone
Haven’t been around much lately but I finally got some time to put the 7040573 carb that Cliff rebuilt for me back on my Judge. The carb I had been running for some time had a plastic choke pull-off and the vacuum line went right into the carb. The one on my rebuilt has two nipples (second pic). One with a line to the carb body. Where does the other one go?
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 08-25-2018, 12:32 PM
racerboy's Avatar
I may have answered my own question by looking at some old posts. I don’t think this dual-port choke pull-off is correct for a RA carb. Can I just cap the one open port for now? Does anybody reproduce the correct single port?
Old 08-25-2018, 01:17 PM
johnta1 johnta1 is online now
It is a RA carb! Just for California though.
(rarer?)
I'd say the extra nipple is for some emission hose.
The base plate doesn't look like it has the nipple for the PCV, so maybe something for that?
I don't know anything about them really though.
(emission carbs)
And plugging it is no problem.
Old 08-27-2018, 10:43 AM
orejudge orejudge is offline
Goes to the charcoal can on core support for California built cars.
Old 08-27-2018, 11:45 AM
Kenth's Avatar
Kenth Kenth is online now
The dual nipple choke pull-off is a Pontiac non-RamAir (and Cadillac) one-year only device.
It´s part of the "choke delay system", the second port is connected to a vacuum tank mounted on passenger side inner fender.
If not used this port needs a plug.
The PCV-hose goes to the 90° nipple right under the carburetor fuel inlet, no fitting on throttle-plate.
The charcoal can has a 1/4" fitting on throttle-plate and a 3/8" ventilation fitting on airhorn.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 08-27-2018, 06:30 PM
Kenth, the 7040573 is not a RA carb?
Old 08-27-2018, 08:21 PM
blue71ta's Avatar
blue71ta blue71ta is offline
7040573 is a Ram Air carb, but the RA carbs did NOT use the dual nipple choke pull-off. It should have a plastic pull-off with a single nipple.
Old 08-27-2018, 09:37 PM
Thanks, I was misinterpreting his answer.
Old 08-30-2018, 10:36 PM
Bet Winner's Avatar
Bet Winner Bet Winner is offline
1969 7028273 pull-off and fast idle cam--both plastic,
I believe that these pull-offs were color coded by carb. I believe that you can buy a generic white one that will look better than metal in my opinion.
But I don't know everything about this by any stretch..........
Name:	Carb--7028273 choke pulloff.jpg
My Wife: "I thought I married a sophisticated business man, but what I actually got was a redneck fisherman with muscle cars."
Some people know all of their rights, but none of their obligations.
Old 09-07-2018, 02:02 PM
racerboy's Avatar
Thanks for all the feedback. I actually tried removing the single-Port from the old carb but I could not figure out how this slides off. Is there some special trick to pulling these off?
Old 09-13-2018, 04:49 PM
Forrest's Avatar
Forrest Forrest is offline
You can try a reverse snap ring/needle nose pliers to spread the metal tabs/tangs apart..be careful though.. the metal can break if bent too much! I have done this many times with success..and a few times with failure (tanks break)..I then tack welded it back and worked o/k afterwords!
