I'm looking for a throttle bracket for my 65 LeMans, I'm swapping in a 455 with a quadrajet coming from a 6 cylinder, year doesnt matter as long as it will work with the factory V8 throttle cable (need a cable as well) . Also in need of the dust shield for a manual trans bellhousing. I'm located in Canada and dont mind paying for shipping as long as its not going to cost more than buying new here....
Thanks Trevor
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt |
PM Bob Vidan. He has quite a few brackets. May even have the cover too.
Excellent, thank you for the tip.
If Bob cant help
I am fairly sure I have everything from a 70 bracket 4bbl cable and a used dust cover ... I have 70's NOS but they are alot more than a repop... year of intake matters.. 71 n older or? 72 for sure n newer is different cables change also 4 bbl is lon ger the hold down changes in 72 ? and the later carbs go from a stud and cotter pin at the carb ... to a snap on ball ... and from a clamp style cable holder to a square plastic plug with a barb ... Scott watcha got maybe when Bob gets done watchin the reruns of womens tennis he will give you a shout out .... or check him out at Zboos pontiac parts hes got alot of nice parts on there for your visual pleasure |
The intake is a 1969, the carb is a 1968 so it has the stud and cotter for the throttle cable. and the car is a 65 LeMans thats getting a 1974 455 so its a bit of a mixed bag...... definatly not going to win any originalty awards thats for sure . I sent Bob a PM to see what he had will let you know.
Thanks Trevor
Hello
I'm still looking for a throttle cable bracket that will work on my 65 Lemans year isn't important as long as it will work. Though I'd try again before buying a repop one. I'm located on the west coast of Canada and do not mind paying shipping. Thanks Trevor
I have one in NY, I don't mind shipping, $35 plus shipping
