Old 10-27-2018, 03:00 PM
63gpman's Avatar
63gpman 63gpman is offline
Default 65-68 P8 4 speed parts
Just trying to document and organize part numbers and interchange for our full size cars.
9787410 - clutch anti-rattle spring (same as a-body) 65-71
9787069 - clutch fork All MT 66-69 and 65 P8 as well as 64-65 T8
9779202 - lower clutch push rod (z-bar to fork) 65-71 P8 + 66-75 A and G
3840845 - swivel for push rod above - 64-69 ALL
9779232 - flywheel 10" standard duty 65-75 ALL V8 (kind of)
9779234 - flywheel 11" Heavy duty 65-75 ALL V8 (428,455,HD)
9787406 - Z-Bar (countershaft) 67-70 P8
9787243 - linkage return spring 67-70 P8
9779217 - linkage return spring 65-66 P8
9779206 - Clutch Pedal 65-66 P8
9787227 - Clutch Pedal 67-70 P8 (although different part # 65-70 are very similar and may interchange)
9779085 - Brake pedal 65-66 P8 MT Power Brakes
9779081 - Brake pedal 65-66 P8 MT Manual Brakes
9786778 - Brake Pedal 67-68 manual brakes
9786781 - Brake Pedal 67-68 Power Brakes or Disc Brakes
9779487 - 1-2 shift rod 65-66 P8
9779488 - 3-4 shift rod 65-66 P8 also lists 9786893
9779489 - reverse shift rod 65-66 P8
9786892 - 1-2 shift rod 67-68 P8
9786893 - 3-4 shift rod 67-68 P8
9786894 - reverse shift rod 67-68 P8 (assuming rods interchange 65-67)
Can't find
Push rod from clutch pedal to z-bar
65-66 Z-Bar (countershaft)
I may dig further, but just wanted to put this somewhere. The clutch/brake pedal brackets are different also between Power and Manual brakes as well as the years, but I did not go that far. I have a set of 65-66 pedals as well as 67 or 68 that I will post photos here. to me it looks like you could interchange the pedals from 65-68 although they look slightly different, the angles and such look similar. more to come....maybe?
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 10-27-2018, 07:36 PM
Stuart's Avatar
Stuart Stuart is offline
I checked the Maxperformance online parts catalog and for some reason couldn't find a part number for the rod assembly, but it is in Group 0.854 which may help your search.
The Z-bar (countershaft) is in Group 0.852.
Part number for 1965-1966 P-8 cars is 9779221
Part number for 1967-1970 P-8 cars is 9787237
Old 10-28-2018, 01:03 AM
63gpman's Avatar
Awesome, thanks!! Here are some photos of 65-66 vs 67-68. Clearly some differences, but they look to have the same dimensions overall. The clutch pedal has a little different swing between them, but don't see that as being an issue if someone wanted to use the pedals from one to the other.
ID:	496155   Click image for larger version
ID:	496156   Click image for larger version
Brad Hansen
Old 10-28-2018, 01:04 AM
63gpman's Avatar
clutch pedals
ID:	496158   Click image for larger version
ID:	496159   Click image for larger version
ID:	496160   Click image for larger version
ID:	496161   Click image for larger version
Brad Hansen
Old 10-28-2018, 09:20 AM
Stuart's Avatar
It's sort of off topic but I was wondering about is what they used in 1971 for the clutch pedal assembly, since they only built a handful of big cars that year with manual transmissions before dropping them in mid-year...whether they tooled up new parts or simply adapted what they had used in 1970.
Old 10-28-2018, 07:48 PM
stevep's Avatar
stevep stevep is offline
Probably were Chevy pedals at that point.
Old 10-30-2018, 10:14 PM
63gpman's Avatar
to answer my own question, yes, you can swap 65-66 pedals with 67-68 and vice versa. I know that the mounting bracket for 65-66 is visually the same and have used them from automatic brakes and swapped in the swing pedals, so one should be able to make pedals work on their full size car with just a set of the swing pedals from 65-68 and their existing automatic bracket. "manual brakes only"
I will say that once a person changes to disc brakes or whatever else, I am not sure that it matters if you have power pedals or manual pedals though and simply will need to experiment with different bore size for the MC to get the feel one is looking for.
Anyway, thanks for letting me ramble.
Brad Hansen
Old 10-30-2018, 10:25 PM
Stuart's Avatar
It's good to have all the discussion on this topic put together in one spot.
Old 06-17-2023, 09:44 AM
57Chieftain's Avatar
57Chieftain 57Chieftain is offline
Bumping this great topic and adding a relevant question to keep it all together. Does anyone know what the difference is between the 65 - 66 and the 67 - 70 countershafts are? As Stuart mentioned above, they are different part numbers. I'll attach a picture of two z bars that I have that I was told were both from 66 cars. One has a slight bend to it and I'm wondering if that piece is bent?
Struggling to attach the photo...
John
'48 Convertible, subframe, disc, PS, PB, AC, PA
'57 Chieftain 2 Dr sedan - 455 2-4Bbl
'57 Star Chief 2 Dr hardtop, tripower A/C
'57 Safari wagon, 4 Dr, A/C
'58 Chieftain vintage race car, Nascar 285hp 2-4bbl
'61 Catalina 2 Dr hardtop, 4speed
'61 Catalina 2 Dr sedan, 455 2-4bbl
'63 Catalina SD Clone, 455 2-4bbl 4-speed
'63 Wagon 421 2-4Bbl 4 speed
'66 Catalina 421 tripower Convertible
'70 GTO RA4 Auto
