Old 02-11-2019, 04:23 PM
Midnight Goat's Avatar
Midnight Goat Midnight Goat is offline
Default 1967 GTO Disc Conversion advice (Scarebird related)
Hello All,
I currently have a 67 GTO with power 4 wheel drums (dual reservoir master). I'm thinking of going the scarebird route but I'm unsure if I should upgrade the fronts only or do all 4 corners. I'm also trying to determine what my total price will be out the door but I'm having difficulty locating a full parts list for all 4 corners.
Here are the kits I'm looking at and associated questions:
https://scarebird.com/index.php?rout...&product_id=68
I have a few different sets of wheels, a set of 17" as well as the stock Rallye II's (I think 15"). Is there a more performance oriented option over the above?
https://scarebird.com/index.php?rout...product_id=178
Is this my best bet for reusing the stock parking brake cable? What's involved in modifying the parking brake cable to fit?
What is used for a parking brake when using this kit instead?
https://scarebird.com/index.php?rout...&product_id=63
Will I be able to reuse the booster I already have or will I have to get a new one along with the new master?
So far I've gathered this parts list from GT182 (Thank you!):
2 - 78 Monte Carlo rotors AX5530 from Auto Plus warehouse
2 - A-6 Bearings - need to find part numbers
2 - A-2 Bearings - need to find part numbers
2 - National Oil Seals PT# 8871
2 - 79 Seville brake hoses..... Dorman H9812
2 - 90 Celebrity calipers... L and R
1 Push Rod Boot - PT# R129TQ (may not need not sure if mine is bad)
Master cylinder from Pirate Jack in Ashville, NC. http://piratejack.net/mck111dbm-univ...tioning-valve/
Don't have any idea what's required of the rears yet. I'm actually surprised there isn't a full walkthrough of this kit on here, seems like it would be a very attractive option.
1967 GTO- 400ci of PONTIAC iron, 4bbl 770 cfm holley,670 heads, headers, 4spd, and a busted fender.
2005 GTO- 400hp of corporate ls2, lingenfelter intake, Corsa sport exhaust, reprogrammed tcm, Boyd Coddington Smootie II's, and a crap load of zaino!
Old 02-11-2019, 06:15 PM
The rears use the Eldo calipers - but you will need custom ebrake cables.
This is essentially a 79-85 Eldo brake system, so if you can get a 1" bore master to bolt up to the booster that would work perfectly.
We also have something in the works that has more braking power but would require bigger rims (disc 15").
Old 02-11-2019, 07:47 PM
mf67gto mf67gto is offline
Try Vic at Control Cables for special park brake cables. Website is http://www.controlcables.com/ Did a nice job on park brake cables for me putting C6 brakes on my '67 GTO with Currie 9" from KORE3
Old 02-12-2019, 03:41 PM
Appreciate the reply! What's the time frame looking like for the new option? I'm not in a terrible hurry and would rather do it right the first time.
Kind of stinks about needing a new parking brake cable (I just put a new one in recently). Maybe I can sell it and recoup some of the cost.
Appreciate it, will keep them in mind when I purchase the kit. What information do you need to supply them when you order?
Old 02-12-2019, 04:00 PM
Give Vic a call and describe what you need. He will have you measure between frame bracket and brake bracket at full suspension droop. If you have pics of the ends you need he will most likely know what you have and will put them on - will look just like OEM. His cables were awesome and less than $30 each. Good luck - very nice guy as well and helpful
Old 02-12-2019, 10:34 PM
GT182's Avatar
GT182 GT182 is offline
Mark, what's the difference between the GTO B and GTO PF kits? They look the same to me.
MG, are you using the stock drum spindles? I've no idea if there is any difference between the 66 and 67 drum spindles. So far I can't find a part number for either year for the spindles. The Catalina spacer Mark sent me made a big difference in the clearance between the caliper brackets and the rotors up front. Keep that in mind when you do the conversion. Mark will know what I mean, and you can see it in the photos I posted.
The guys at the Parts Store I hang out at were really impressed with my conversion in the end, and said that if anyone came into the store looking to do a conversion they'd be checking in with Mark, and would want them to see my results.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 02-12-2019, 11:37 PM
GT182: there are several variants of those spindle, mainly bolt hole sizes.
Midnight: 4-6 weeks. Our large rear drum-in-hat may reuse your cable if modified.
Old 02-13-2019, 12:07 AM
GT182's Avatar
Good to know. Thanks Mark.
Gary
Old 02-19-2019, 11:42 AM
Awesome! I'd like to start aquiring everything that is needed, is there an updated parts list yet?
How would the cable need to be modified? Is a fitting mod or the cable itself?
Old 02-19-2019, 12:08 PM
GT182's Avatar
Midnight, Old Goat 67 has the complete disc setup for the rear. Send him a PM if interested.
I've been asked why I didn't go with rear disc brakes. For me it isn't really necessary. The discs up front work just fine and the car stops great now. But that's just me and my thoughts.
Gary
Old 02-19-2019, 01:45 PM
455HOGT37's Avatar
455HOGT37 455HOGT37 is offline
How about the tall spindle conversion using wrecking yard Caprice spindles, 1LE camaro rotors and the common as dirt full size calipers? That used to be a very low buck and effective solution. And there are plenty of low cost options for the rear. Looks like Summit has several for about $350. Hardly even worth the time to go to a junk yard at that price.
Old 02-19-2019, 08:52 PM
yes, email me and will send you one [email protected]
Old 02-25-2019, 11:28 AM
E-mail sent! Thanks.
