Old 02-27-2019, 05:51 AM
piot piot is offline
Default How to call this part???
Good evening.
Does anybody know what this part is for and how it's called?
I don't know how to attach pictures here so please click the link below.
https://s1344.photobucket.com/user/2...1lzt5.jpg.html
It's not connected with the carburetor.
Thanks! Piot
Old 02-27-2019, 06:15 AM
Scott Thelander's Avatar
it looks like the transmission Kickdown solenoid/switch
Old 02-27-2019, 06:28 AM
Old Goat 67's Avatar
That are correct. Yep, Photobucket sucks now.
Old 02-27-2019, 10:57 AM
GM had 2 early names for that. Either "Kick Down Switch" or "Downshift Switch". They can be found under Group number 4.057 and one other number that I cannot recall at this time.
Old 02-28-2019, 01:38 AM
Thanks guys for your answers.
I guess I've found the switch on ebay:
https://www.ebay.com/itm/1964-Pontia...HFDQ:rk:2:pf:1
...but I think it's not necessary to replace mine because my car is downshifting when kick down.
I just was not sure what this part is good for plus it looks kinda weathered so I thought replacing it is not a bad idea.
Old 02-28-2019, 09:59 AM
What year is your car? The one you posted is for '64. They are slightly different for almost every year. While you can use a '64 on '65 and '66 some wiring modifications would be necessary. If that is not your thing then I suggest you replace with the one made for your year.
Old 03-01-2019, 03:34 AM
Oh wow! I didn't know that.
Mine is a 1966 Bonneville 421ci.
The part on ebay looks identical as mine. You can tell by comparing both photos.
Old 03-01-2019, 08:52 PM
FYI: There is suppose to be a bellows style boot on that. It will cover your plunger shaft and make your switch look a lot better. Check the Ames catalog, he may sell them.
