Old 03-08-2019, 10:14 AM
chrisp chrisp is offline
Default 64-67 Z-bar/ clutch pedal repair bushings
64-67 Z-bar/ clutch pedal repair bushings these flange bushings repair the wearable egg shaped holes & saw cut ends of your worn clutch linkage . $25.00 for 3 pcs.
Old 03-13-2019, 07:16 AM
5 sets available 7 sets sold
Old 03-13-2019, 08:36 AM
wbnapier wbnapier is offline
Do you have a pic of the bushings?
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 03-13-2019, 11:41 AM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
PM sent
Old 03-16-2019, 09:21 AM
Pm & email sent.
Old 03-24-2019, 11:04 AM
Will repair other years with 5/16" ends / holes . 4 sets left
Old 03-26-2019, 10:22 AM
455hota's Avatar
455hota 455hota is offline
PM sent.
...Steve T.
Pontiacs:
1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior)
1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior)
Non Pontiacs:
1966 Lincoln Continental
1967 Ford Thunderbird
1979 Lincoln Continental (Towncar Option)
Old 03-27-2019, 08:14 AM
The repair bushings go in the holes [2]on the countershaft[z-bar] & 1 in the clutch pedal hole. If your 3 holes are elongated from wear it takes the slop out & the bind from metal to metal . Generally the male ends of the countershaft get a cut mark in the ends as does the clutch adjustment rod . You would weld the cut mark & file fit it to fit the new bushings & drill [3/8] the 3 holes to accept the repair bushings& put a dab of good grease Very smooth pedal feel.
Old 04-12-2019, 07:11 AM
Bump
Old 04-21-2019, 08:52 AM
$30.00 3 pcs. shipped with USPS & tracking / delivery confirmation.
Old 05-11-2019, 07:21 AM
Plenty in stock with excellent feedback.
Old 05-11-2019, 09:29 PM
400 4spd.'s Avatar
Also, what material are the bushings made of?
Old 05-13-2019, 08:26 AM
Oilite Bronze with flange .
Old 05-14-2019, 11:41 AM
indetrucks's Avatar
indetrucks indetrucks is offline
Interested as I was about to order a new Z-Bar due to it having an elongated hole.
Mind sending me some pics of the bushings?
Is welding 100% required?
emailchristian (at) gmail (dot) com
Thanks!
Old 05-14-2019, 04:49 PM
Thanks!
The elongated holes would need to drilled to 3/8" to accept the repair bushing , check both holes on zbar & the clutch pedal hole as well . Welding is only required to fix the male ends on the zbar linkage from the pedal to zbar ends & clutch adjustment rod end . Also makes a nice smooth pedal feel . email sent.
Old 05-14-2019, 09:20 PM
Thanks!
[email protected] is not a good email / failed to deliver
Old 05-15-2019, 11:39 AM
indetrucks's Avatar
That is because you forgot the word "email" in front of it
Don't worry, you aren't the first to do this.
Old 05-25-2019, 06:56 AM
Bump
Old 06-09-2019, 03:46 PM
Bump
Old 06-22-2019, 07:21 AM
Still avail.
